The short you read about is in the power supply. You want to repair your TV. There is no reason to purchase or hire a tech. In this specific model and there are two of these (models). The model numbers are the same, just minor differences (power supply). Before you replace the fuse. Snip one end of diode D620 and lift it above the board enough to clear. Do not remove the diode, do not replace the diode. Now replace the fuse, your TV is repaired. If you cannot find D620, You will search for D611. In this case the same model TV just a minor number difference (power supply).
Hi Jeffrey,
There is some short circuit in the power supply board which is causing this. Do not just go trying new fuses, it may increase the damage. Please consult the TV Tech to take care.
Good luck.
