Water Heaters Logo
F
Feona Gray Posted on Dec 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water output to all taps is really slow to the point that it is impossible to shower - cold water supply is fine from taps serviced by this boiler. What might be the problem?
If cold water output to taps/shower is ok, which pipes might be clogged and how can this be resolved - by servicing boiler or are we talking about something more complicated?
Louis F Hoholek Jr
Level 3:
  • Master 1,140 Answers
  • Posted on Dec 03, 2015
Louis F Hoholek Jr
Master
Level 3:
Answers
1140
Questions
0
Helped
258845
Points
4510
If you do not have copper plumbing, the interior of the pipes is clogged. The shower head could be clogged too. Buy a new shower head even if you do have copper pipes.
pacman020
Level 2:
Habit-Forming:
New Friend:
  • Expert 56 Answers
pacman020
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
56
Questions
0
Helped
7358
Points
149
The boiler is clogged or has a hole in it.
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
I have a Vaillant Combi boiler, recently serviced by British Gas, given all clear. Problem we are having is the downstairs hot water tap it is a mixer tap, the cold water is fine but the hot water is
Boilers are inherently dangerous for the average DIY for so many reasons, contact British Gas and have them come back and fix it, tell them it was fine before the "service". They may simply have a control valve shut off.
Baxi boiler no water in hot water taps
If no hot water it is the diverter valve in the boiler. If no cold water the tap in the mains water supply to the boiler may be turned off
Greenstar 30cdi no hot water
It is the shower head or plumbing that has a built in mixer or reducer.
Greenstar 30cdi hot water issue
The problem is not the water heater. The shower has a mixer or a limiter built into the plumbing so that the water wont get hot. It is a safety feature to prevent burns and protect children from scalding.
1helpful
Changing hot tap washer
Hi, if you have a mains pressure HWC, all you need to do is shut the cold mains off either from your cylinder cupboard or on the street. Shutting it off on the street is probably better as things like shower valves tend to pass water through and start a back feed.
I have a vaillant eco pro 28 combi boiler. no constant hot water unless tap is on really low.
Oh some of these there was a small black heatexchanger just for hot water they some times block up . or it could be a blockage in the water section where it flows in .I know Valliant have a very good tech line and fitters who do house calls .
Code 13 help... Everytime I go to use the shower (a mixing system of hot and cold) Code 13-- Code 12 the system shuts down. If I just use hot or cold I am fine-- Any one?
if cold supply to boiler and shower are off the same feed this could be your problem as the boiler governs flow of hot water best of luck
Vaillant ecoMAX 828/2boiler goes on & off when running hot water!
water must be set at 3lts a min ,check diaphragm valve move when hot tap is on, check microswitch ,best of luck
3helpful
2answers
Top Water Heaters Experts
vince
Steve Sweetleaf
Steve Sweetleaf
Are you a Water Heater Expert? Answer questions, earn points and help others
