Televison & Video Logo
Alex Bamford Posted on Dec 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MUTE BUTTON HAS BECOME HARD TO PRESS. WILL WORK WITH PRESSURE.??????????
Kaye Day
Level 3:
  • Master 744 Answers
  • Posted on Dec 03, 2015
 Kaye Day
Master
Level 3:
Answers
744
Questions
Helped
223262
Points
13385
Possible crumb or something stuck in it. Try cleaning with toothpick and air spray
Everything works except the volume why
Mute Button
https://www.google.com/search?q=clarion+nx501+mute+button&
NX501E NZ501E
Clarion Global https://www.clarion.com > MungoBlobs > NX501... PDF • Press this button more than 1 second to stop video and audio media. [MUTE] Button. • Mute or Unmute the speaker. • The symbol on upper right area of the ...
123 pages
Switching On, Off Or Mute; Audio Source Selection; ...
ManualsLib https://www.manualslib.com > ... > User manual Press the button again to cancel the mute function. ... by turning off the vehicle ignition and removing the vehicle ignition key. Audio source selection. AM/FM.
NX501A
Clarion Global https://www.clarion.com > NX501A_ENG PDF • Press this button more than 1 second to stop video and audio media. [MUTE] Button. • Mute or Unmute the speaker. • The symbol on upper right area of the ...
138 pages
Functions Of Remote Control Buttons - Clarion Manuals
ManualsLib https://www.manualslib.com > manual > Clarion-Nx501 Functions Of Remote Control Buttons - Clarion NX501 Owner's Manual & Installation Manual ... and audio media. [MUTE] Button. • Mute or Unmute the speaker. • The .
3answers
I have the Garmin nuvi 255W GPS (car). The voice anouncements stopped in mid instruction and I have been unable to get it restarted. Maps still ok. What's my problem???
Did you tried reset procedure.There are two resets. 1) Soft reset. 2) hard reset. The hard reset will delete all the data in your GPS so get the back up first before performing the hard reset. If you want to try this, make sure you've backup the data in your unit before answering to Yes. --------------- Reset procedure sets the unit to Factory settings on which the unit actually came to you.So all the sound and other settings get automatically set and unit mostly gets working in most of the cases. --------- The procedure is as follows:--- In the Quick Start Manual of Garmin Nuvi 255w GPS, it stated that you can reset the unit by pressing the RESET button at its bottom. However, the RESET button is not found on some Nuvi 255w.
Additional information in the Owner's Manual stated that if RESET button is not found, slide the POWER key and hold it for more than 8 seconds will do the same.
----------------- The Hard reset Now:--Try this only if the above soft reset does not helps:--- Another section in the Owner's Manual under the title "Clearing User Data" stated that holding your finger on the lower-right corner of the screen while turning on the unit and keeping the finger pressed until a message appear, that will allow you to delete all user-entered information. a message window pops up asking about "Do you really want to erase all user data?". There are 2 buttons to select, Yes or No. select "yes" to get the reset completed.Then check.----------------
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Sep 23, 2010 • Garmin GPS
My volume and mute button has stopped working all other buttons are functioning properly
Press the mute button and then turn up the volume button. If no sound still then press the mute button again. If we are talking about a Remote, then change the batteries.
Same problem as don5625.my moxi box will not control volume mute or power on my olevia lcd hdtv
Is this the style of Moxi remote that you have?
If so try these steps to find your TV
1. Turn on the power to your TV.
2. Press and hold down the MOXI and OK buttons.at the same time until the LED at the top blinks twice.
3. Press the numbers 9910 on the remote and the led should blink twice again.
4. Press the mute button. If the TV mutes then press OK to lock in the code. If the TV does not mute press the up arrow once then press mute and continue to press the up arrow once then press mute until the TV mutes once the TV mutes press the OK button to lock in the code.
*** Note this may take a couple minutes of trying to cycle through the code list to find which one will work with your TV *****
Good Luck...
I have a Tevion (Tev 8400) from Aldis that hardly plays any DVDs. How can I unlock this? I've searched and other models of Tevion require pressing the mute button in the instructions, but my remote for...
Maybe what you could try is getting a one for all remote control with a mute button on it. This may make the DVD play if you say that some other models work this way.
2answers
Mute button wont turn off
HERE is your manual in PDF format.
This unit doesnt have a volume mute function.
What are the problems you are experiencing.
If it says Mute or ATT on the display - it is the cellular mute function turning off the volume for an incoming call.
Page 34 details turning on and off the cellular mute function.
You also may try a hard reset by removing the face, and pressing the reset button.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question
Mute - Turn On??
Welcome to Panasonic :-)
The mute button works when you have a speakerphone call. That means SP-PHONE pressed and press MUTE and it flashes to let you know it's on mute.
Maybe software version 9.0 will fix the mute to work on handset calls.....
Carl
1helpful
Resetting the parental control password?
try master pass 3308 Childlock The CHlLDLOCK function prevents chiIdren from watching TV. HoId down the F button and then press the MUTE button until the symboI ? ? appears on the screen, and the TV enters the CHlLDLOCK mode. Except for the symboI? ?, the screen becomes blue back and mutes when you press the buton to turn the TV off, then turn the TV on after setting the CHILDLOCK function. To unlock the TV, hoId down the F button and then press the MUTE button again. Note: The CHlLDLOCK can be set or cancelIed only by the remote controI. After setting CHlLDLOCK, secure the remote control in a safe place
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
