Cars & Trucks Logo
Ann Young Posted on Dec 02, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problems with starting Sedona 06 starts first time other times takes half hour garage thinks its immobiliser problems
Claude Kayser
Level 3:
Top Expert:
  • Cars & Trucks Master 9,098 Answers
  • Posted on Dec 02, 2015
Claude Kayser
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067244
Points
28436
Starting difficulty due to defective anti-theft control module ...
repairpal.com > Problems > Kia > Sedona
Kia Sedona Starting difficulty due to defective anti-theft control module. ... Learn more about this problem, when it occurs and how to fix it. ... 2006 Kia Sedona.
Kia Sedona wont start - 2006 Kia Sedona - RepairPal
repairpal.com > Questions > Kia > Sedona > 2006 Kia Sedona
Ok all. Heres a stumper. My wifes Kia minivan was running fine. No issueswhatsoever. well maintained...you get the drift. Last week, we came home from ...
2006 Sedona not starting - Kia Forum
5 Related Answers
Anonymous
  • 375 Answers
  • Posted on May 18, 2008
SOURCE: 2006 Hyundai Azera problem starting
Buy only quality brand gas like Shell and add a bottle of fuel injector cleaner during your fill up, after 1-2 tanks if the problem persists then you can eliminate a problem with the gas or dirty fuel injectors. At this point you should have replaced the air filter and done 2-3 oil changes, sounds like the battery and starter are fine. Track what you put in the tank and then go back to complain if you still have a problem.
Anonymous
  • 6966 Answers
  • Posted on Sep 04, 2008
SOURCE: 02 sedona hard time starting and mass airflow sensor issues
Appreciate the direct "Ask Me".
Hard starting could be caused by a number of faults such as weak battery corroded/loose battery terminals, fuel delivery issues and others which may include as you posted the MAF sensor. In my country however, most Kias have a peculiarity. They like to be well warmed up (even if it is hot here). Hard starting specially after short hops/trips is actually the ECU/ECM/Control Module or the car's computer getting mixed sensory inputs. The corrective action is to warm up the car fully before using. In some instances, it may also be required to reset the computer by removing the negative battery terminal for a few minutes. Pls bear in mind that some alarms are triggered this way and/or some car stereos would require a security code if the battery is removed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Anonymous
  • 83 Answers
  • Posted on Sep 23, 2008
SOURCE: my kia sedona wont start just click when turned on
Couple of things to try.
1. Check that the battery connections are both clean and tight on the battery.
2. Check water level in the battery is above the plates that you can see in the filler holes.
Caution:
(Handle the battery with care as the water in the battery has been charged and becone sulphuric acid which will burn your skin. Do not get this in your eyes.)
3. Turn the headlights on then start the vehicle, and if:
a) the lights dim the battery is not connecting properly or faulty, or:
b) the lights stay on full it would the starter motor relay or solenoid (part of the starter motor).
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Feb 18, 2009
SOURCE: Fiesta Diesel (Y Reg) intermittent starting(flashing immobiliser)
diesel ,,,just bypass the immobiliser ,20mins work
Anonymous
  • 1986 Answers
  • Posted on Aug 12, 2009
SOURCE: Flat battery caused immobiliser problems
1-insert and remove key from ignition two times
2-close and open driver door two times
3-insert and remove key once from ign.
4-close and open drvr door twice
5-insert key into ign.,then close driver door
6-turn key to on (not start) then off, twice this is rewrite mode,have all remotes to reprogram it will clear any lost remotes.
7-remove key from ignition,the door locks should cycle twice.if not start over.it may take a few tries.
8-press lock/unlock together and hold for a second
9-release,and press lock on remote,the door locks will cycle confirming program.continue to do other remotes you have,steps 8 and 9.if only one in possession,you are done. To end mode open door or insert key into ignition.
You'll need to follow the steps with no more than a 1-2 second delay between each step.. hope it works
I replaced immobilizer coil . still getting theft light code 11
Reading Ford Immobiliser Codes PATS - YouTube
? 2:00
https://www.youtube.com/watch?v=0kBZeBbb9PM
Mar 31, 2011 - Uploaded by Ask The Mechanic
How to read Ford Immobiliser codes when your car won't start. PATS (PASSIVE ANTI THEFT SYSTEM) http://www.askthemechanic.co.uk. ... and milage appeared, but red light still flashing 1:6 Found Fordwiki, and Youtube, ... a scanner with Body Control software you would get a code of B10D7 for code 11.Missing: taurus
2003 Kia Sedona120,000Visitor ... no knowledge of this easily findable problem with the Vehicle Immobilizer Control Module. ... Upvote (11) .... I have replaced the temp. sensor and I am still getting a PO118 code. ... Check Engine Light Stays on since purchase of 02 kia sedona with 89,000 mileage. ... Ignition Coil May Fail.
KCSS-Transportation-Technology - Ford Passive Anti-theft ...
3answers
Kia Sedona 06 refuses to start garage thinks problem with immobiliser starts when locking and unlocking doors
www.kia-forums.com/kia-carnival-sedona-2006/39139-2006-sedona-not...
Jun 17, 2007 - 10 posts - ‎8 authors
I'm told there's another '06 Sedona also sitting at this dealership with the same ... Each time the car won't start, all the panel lights come on, the ... please help - 2006 Sedona won't start - Kia Forum
1 post
Jun 30, 2014
Cranks but won't start - Kia Forum
Sep 12, 2011
Won't stay running - Kia Forum
Dec 28, 2010
2006 Kia Sedona won't start - Kia Forum
May 12, 2010
More results from www.kia-forums.com
I need to nou why my chery qq3 2010 0.8l takes half an hour to start in the morning after it starts 1se it wil start quily every time after that ? But tomorow same story the car stAnds on km75000 No enjin...
In order to start an engine needs compression, timing, the right amount of fuel delivered into the combustion chamber, a spark sufficient for combustion and a good cranking speed.
There isn't a way for anyone here to guess which of those requirements are absent and only checking the car when it doesn't start will reveal the fault. These days most cars are fitted with an immobiliser and part of the checking will be to ensure any immobiliser is fully disarmed.
Honda crv start problems
First check the immobiliser is disarming before you go further. The vehicle handbook will provide details.
3helpful
Kia carens 2000 diesel immobiliser problem
The mechanic that you talked to was exactly right
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
My 06 sedona wont start just a clicking noise, radio and lights work. Just got a new battery for it and nothing changed. Is there a fuse/relay problem or probably the starter?
Try jumpstarting it. My 06 has done that a few times and jumpstarting has worked every time. Usually, one of the kids left a dome light on or something.
1helpful
6answers
Brand new 2009 Honda accord problems starting
I have a 2009 Accord 4 cyl. with 10,000 miles. I am having difficulty starting the car occasionally. Dealer said there is nothing wrong with the car.
My 1972 911 wont start
Not a Porshe specialist, just a superbike engineer......my brother has an '87 911 that has had similar problems.
On his it was down partly to the aftermarket alarm/immobiliser system and also the main fuseboard.
IMMOBILISER/ALARM SYSTEM
This was fitted (very badly) under the bonnet space carpet......the car had been parked up for a while and the control/relay modules were half full of water.
Unplug them, open the casings up carefully and blow the water out.
Rinse circuit boards in distilled water and then blow out with Contact cleaner (Trichloroethylene aerosol)
VERY carefully scrape any corrosion bridgeing tracks or component pins away then rinse again with Trichloroethylene.
If there are any mechanical relays in your system carefully remove plastic covers and clean points contact faces with paper and Trichloroethylene......DON'T go scraping the relay coils or cleaning contacts with abrasives (they're coated with platinum to prevent oxidation when they arc) .
Be really careful when you're handling the boards....The build quality isn't great on some of them!
Of course, if the underbonnet space on yours is dry/clean and the immobiliser modules are not wet then this will be of no use at all !!
THE OTHER BITS
Could also be ignition coil pack failure or ECU component failure......BUT.....First....
Check main ignition power supply relay FIRST and then take time to clean any corrosion from main fuseboard/relayboard terminals on inner wing inside bonnet area as this seems to be prone to general ageing. Take EVERY fuse and relay out, one at a time so you don't get confused with where they go back and clean all terminals with fine screwdriver/needle file/fine wet and dry paper....rinse with Trichloroetylene spray
When you've done it I'd give the general area a light spray with something like DuckOil or GT40 aerosol to help keep corrosion at bay in future
Good luck with this.....It'll take a bit of time to do it all but chances are it's not the ECU or Coils. Get the simple stuff pristine first, before you start chucking expensive bits at the problem.
9 out of 10 times it's the answer!!
Cheers. Rob.
19helpful
10answers
Starting problems with Renault Megane i Dynamique
car won't stat when clutch is pressed in,but will only start when brake is pressed in.
2answers
Possible immobiliser cut in Grand Vitara 2.0 td 2000
i had the same problem, only option is garage to re set it when they give it diagnostic check. fixed mine but!!!!!!! they said i had a slight coolant leek half hour later head gasket went!!!. had it fixed now, black smoke every were and no power. think i opend a can of worms should have just sold the dam thing.
good luck
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
