Question about Mitel 5340 IP Phone
We cant get the recorded message for night mode to change. How is it done?
We have a message and we assign it. But the message that is already there keeps coming through. We don't know how to find the current message in the system and delete it or record over it. Please help?
  • 60 Answers
Here is a link to the user manual for your phone. The directions are very vague about turning off the night mode. They state: To disable Night Answer: • Press the key you programmed to Night Answer.
If you look on page 30 of the manual it tells you how to get into the settings mode. You should be able to go into settings then scroll through the settings to find out which key is programmed for Night Answer. http://edocs.mitel.com/UG/EN/33_5330-5340_UG_EN.pdf
Posted on Dec 02, 2015
Testimonial: "The settings don't offer us the information that allowed us to figure it out. We had already tried the solution you offered. What would happen if we actually just reset the whole system? Can we even do that?"
6ya staff
SOURCE:
Panasonic KX T7433 - I need to change the night mode message howevern when I select intercom 165 or intercom greeting and change the message I am unable to select the new message as the new night mode...
It's only that simple if you have a guide to what Custom Service or greeting plays now. When the system moves from Day to Night mode, the installer assigns a menu that plays. You can change it if you know which one. If you don't get the right one, there would be 98 other custom service and 31 other Company messages that you could record to and they'll never play.
Carl
Aug 23, 2011 | Panasonic KX-T7433B Corded Phone
How do you erase and change after hours greeting?dhalman
Call voicemail by pressing the Intercom button then dialing 777, when it answers login by dialing 99# followed by the password(default is 1234#) then press 9 for system features menu. Press 3 to choose Automated Attendant, the system prompts for the Auto Attendant number(1-4), start with Auto Attendant 1,if you do not know which one is being used by pressing 1. Press 2 to choose Night Menu, press 6 to change the Night Menu prompt. Lift the handset, press 1 to record your new Night Menu prompt using the handset, press 1 at the end of your recording. To listen to the new recording press 23, to immediately re-record press 21, to save the recording press *#. Press # to save all programming changes and activate new recording. Press *7 to return to system features menu or hang up to end programming session.
Changing the Auto Attendant prompt should be done when you are able to do a test call on each line to verify that you have changed the correct prompt(in your case after hours or by putting the system in After Hours mode manually to ensure the After Hours prompt is active) for each line being answered by the Auto Attendant. By default all lines are assigned to Auto Attendant 1, if your system has been modified to use a different Auto Attendant for some or all lines, you will need to repeat the above procedure for the Auto Attendant being used. If at any time you get lost or confused while in the voicemail programming, hang up and start over. Once you get comfortable with navigating the voicemail programming, it gets easier. If you have trouble send a comment, I will try to help.
Feb 10, 2011 | Lucent PARTNER18 Corded Phone
Hi,How do I change the message that plays
This may be specific for my system, but hopefully it helps:
Connect to your voicemail (for us, we can either hit the voicemail button or dial 1650)
Once in, press #6, it will ask for a mailbox number, dial *9998, it will ask for a password (the default is 1234#)
Press 5 to modify messages.
Press 3 to record custom service menus.
It will ask you to pick which menu (1-100). Our day menu is 1, and night is 2. I'm guessing yours will be the same.
From this point, it becomes the same as recording a standard voicemail greeting. It will play the current greeting and you can press 1 to re-record it. Do so, and then press #. Press 2 to accept and you're done!
Dec 22, 2009 | Panasonic KX-T7630 Corded Phone
Our Automated Attendant for our Norstar M7310 is picking up the wrong message. Where do we change that?
assigning messages is done by
feature 983>1020000>AA>Table>table 1>Greeting Type
depending on how you have the business hours times set it'll play the greeting you want. Typically I set the greeting type as morning:1, afternoon:1, Evening:1 and Non-business:4. then under business hours I set them up as mon- fri morn:0800am, aft:0800am, eve:0800am and nonb: 0500pm. sat and sun as morn:1200am, aft: 1200am, eve:1200am, and nonb: 1159am
press Rls when finished
that way when a caller calls between 8am and 4:59pm they get the day greeting and from 5pm to 7:59am they get the night greeting (greeting 4) saturday and sunday play the night greeting all day.
Dont forget to record greeting 4 as your night greeting.
Oct 14, 2009 | NorStar M7310 Corded Phone
Locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Jul 28, 2009 | Sony Televison & Video
Change night message
the night mode message that is being used is the main phone's (phone with lowest Ext. number) night mode message that was customized through it's voice mail.go on the main phone and listen to its voice mail. (voice mail ext. usually 165)continue listening until you hear some options.select the voicemail management optionthen select the change personal greeting optionthen select the after hours greeting optionhope this helps!
Feb 19, 2009 | Toshiba DKT-2010 Corded Phone
Night Service and Diver All Call to Voice Mail
make sure the call rerouting always is setup and points to the vm huntgroup, then check the call rerouting assignment points the answer point extn number to the relevant always alternative in night1 and night2 mode
ie; always alternative 10 set all to Reroute and supply vm huntgroup number then program call rerouting assignment for extn during night1 and 2 to 10.
let me know if this resolves the issue if not it could be a number of other timer related / vm configuration / call routing problems which might require a more indepth investigation
Feb 09, 2009 | Mitel 5020
Selecting a custom recording.
I was told that the day and night settings in the local applications must be the same. It is in your night call routing table that you need to place the extension in order for the system to know which recording to play when. Then, your system will play the application when it is set in night mode. Hint: When you place the extension in the call routing tables make sure the extension is placed ABOVE the +ALL CALLS line, if applicable, and your ring-in-destination is set to your appropriate application recording. I hope this helps.
j
Dec 15, 2008 | Inter-Tel Axxess Corded Phone
How to change the voice mail message on KP DCS - 24B LCD samsung
I have the manual for the DCS series and there is no help regarding this.
It does say how to turn from auto to manual and make sure that the time is correct.
1. If the manual NIGHT key is pressed BEFORE the system automatically enters night service then the automatic night service timer tables will be overriden until the system is manually restored to day mode.
2. If AFTER the system automatically enters the night service tables and will not be overriden.
Nov 17, 2008 | Samsung Prostar DCS-24B-LCD Corded Phone
Enable Custom Messages
It's hard to see what you recorded the custom messages on, since you left that part out.
I'm guessing that whatever you recorded the messages on has a manual. Try reading it. Is your day greeting a custom message or is it one of the 32 announcements? However you play that message, you need to either replace it, or assign a new message or mode to the auto attendant.
Carl
Aug 25, 2008 | Panasonic KX-T7453 Corded Phone
Mitel 5340 IP Phone Logo
749 people viewed this question
Top Mitel Computers & Internet Experts
Vincent G
Vincent G
Vitally Alcher
Dan Kostella
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
