I am sorry, but there is insufficient information to give a proper answer. If it is a vented logset, is it in a vented indoor firebox/fireplace or an outdoor fireplace?
Does your fireplace have a thermostat connected? If so, that may be why the pilot stays on and the burner goes off. Otherwise, it could be a bad thermopile. If that is the case, I recommend you just replace the entire pilot assembly. It is an older model and manuals can be hard ti find. If you still have trouble, I recommend you contact a local certified gas appliance technician.
The Insta-Flame burner was a product of Majestic Fireplace/Vermont Castings, which went bankrupt and is no longer in business. However, Monessen Hearth, bought the gas fireplace and gas log part of the business. But, their new model numbers don't match up yours. If you could provide me with how old your fireplace is , the full Model Number and Serial Number. I may can help you.
Little documentation on this fireplace but it appears to be a vented wood-burner(?) If vented, there should be no problem using gas logs. If burning correctly, you may consider cutting back on the flue and intake air, as moisture build-up is the biggest drawback to gas fireplaces. Too much air is just wasting gas.
It has a panel hidden under the white fiber hearth bricks at the front bottom of the unit. you need to clean the lava rock off of them, pull both of them up, and then you will see the hidden linear cover that allows you to access the valve and light.
you must keep the burner and the pilot light area clean and free of dust also,the area where your burner gets air most of the time it has an adjustment to give it more or less air.I have had my dyna glo vent free model for 8 years.A good cleaning in late fall with low pressure air and 1 or 2 times through the winter depending on conditions of use.
gatesmason88
