Dryers Logo
Posted on Jul 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gas dryer not maintaining heat. 70 Series Kenmore/Whirlpool 76722
The dryer heats at the start (after rest), and maintains the heat for about 15 minutes. After that, the dryer continues to tumble, but the dial (i.e. control timer knob) never moves if Auto Dry is chosen (the knob does move in Timed Dry.)
I did remove the front panel plug & can see the heating elements glowing intermittently. The light cycles on & off once (not sure if that's right?)I don't know where the fuse is(even with the repair parts list I can't make it out), but if the dryer's heating at all, does that mean the fuse is OK?
Anonymous
Level 3:
  • Whirlpool Master 1,606 Answers
  • Posted on Jul 19, 2009
Anonymous
Whirlpool Master
Level 3:
Answers
1606
Questions
Helped
570314
Points
5623
Fuse is ok . Problem is the soils on the burner valve . If the dryer heats when started , the electricity goes thru the coils to open the valve . Once the coils get warm , 1 will open (short) until it cools back down . The coils can be replaced just by removing the front panel . Only 2 screws hold the coils in place . No turning off gas , dissasembling dryer .
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 • Dryers
1helpful
Kenmore 70 series dryer starts and heats up then shuts off
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Kenmore 70 series gas dryer - does not start when pushing the start button
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
2helpful
Gas dryer not maintaining heat. The dryer heats at the start (after rest), and maintains the heat for about 15 minutes. After that, the dryer continues to tumble, but the dial (i.e. control timer knob)...
The problem is with the 2 little circular black coils next to the ignitor. They need to energize before the gas valve can open. They tend to get weak over time. I am 100% sure this is your problem. Good luck :)
2answers
My gas dryer stopped heating it is a Kenmore 70 series. I am getting good gas flow but dryer will not heat.
Try this link I hope it helps, I know it helped me a ton!! ps don't forget to rank my help. Thank you and have a nice day!
http://fixitnow.com/wp/2004/11/13/mailbag-how-to-troubleshoot-a-gas-dryer-with-no-heat/
I have a kenmore gas dryer modal # 76722691 76722, it runs but no heat. i did clean exhaust vents. I feel no heat.
Do you hear a snap when it first starts? If yes check the ignitor. If no check the thermal fuse and/or the thermostat.
Eric
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 • Dryers
1helpful
4answers
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Kenmore gas dryer 110.72512101
try your pipes at the back,you may have a split
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
