Question about Halonet 99-05 BMW E46 3-SERIES 2/4/5DR, CONVERTIBLE: 318i, 318is, 318ti, 320i, 323i,
Brake system failure
Front brake calipers functions properly but rear brake caliper don't have enough pressure to supply during braking
    Habit-Forming:
    New Friend:
  • 26 Answers
I think brake proportional Valve (or Brake pressure regulator) which usually a part of Master cylinder is suspicious.
It regulates pressure to Front and Rear brake line.
If I were you, I try to draw air from Master-cylinder side (not Caliper side).
(Bleed from connector between Master-cylinder and pipe, same way as caliper. someone keep pushing brake then you lose connector then tight. Don't forget to put towel under master cylinder to catch brake fluid)
If air trapped in Proportional valve (pressure regulator), pressure won't relay to rear brake line but only front side.
Front has two separate line from master cylinder (right and left) but rear goes in one line from master cylinder then separate at rear.
Did you noticed both rear brake dragged when it's hot day ?
Because when air get hot, air expand and pushes to caliper and drag but not respond to your pedal.
(calipers don't respond when you push pedal, but it's pushes calipers by itself even you are not pushing pedal, when it's hot because air expand)
Sometimes, seal get old and lose pressure for only one side (front or rear).
if this happened after you did brake job, or you notice your brake was vapor locked (too much brake on hot day then brake fluid boiled), maybe air bleed and whole fluid change may solve.
if you didn't have any unusual activity but it gradually losing pressure to rear, I suspect master cylinder (proportional valve seal).
Sorry I don't have exact e46 master cylinder diagram but basic diagram, hope you can understand what I am talking about.
Picture shows "leak" but this case "Air" in somewhere in pink.
or lose seal on rear piston.
Posted on Dec 02, 2015
    Top Expert:
  • 53,746 Answers
The rear brakes will have less pressure to no pressure under light braking to moderate braking
you only get full pressure under heavy braking because of the proportioning valve in the rear brake lines
have an accredited brake specialist shop check the pressure under brakes
SOURCE:
2005 Chevy Equinox left front brake caliper locks up
Your vehicle should have rear drum brakes...They have to be adjusted manually for correct adjustment...People say they self adjust but it is not good enough....by adjusting the rear it will decrease the pressure on the front and deliver equal braking...This will help eliminate caliper pressure overload....I'm not saying that is your caliper problem but it is insult to injury and will save the life of front brakes.....Now your caliper problem..FYI..A rule of thumb is anytime you change a caliper you should always replace both calipers to have identical braking pressure".The same with brake hoses and rear wheel cylinders.....The caliper that froze in the first place got hot and boiled the brake fluid and quite possibly partially collapsed the caliper brake line/hose inside as Clint and Frank stated....I am going to guess that the first caliper froze under normal conditions however got hot enough to internally damage the caliper line/hose...Then you may think of the pressure regulator being bad in which case could be a problem......So this is what you do".Since we know the left front caliper line/hose has been exposed to heat it needs to be replaced anyway...also the fluid was boiled and it needs to be changed / bled...The new caliper that froze should be ok unless it was bad off the shelf which is rare but possible."..Change the line/hose,bleed the brake system and let the mechanic test drive before you pay and leave..The mechanic will know before driving if the new caliper that froze is bad or not by rotating the wheel...This is the cheapest way...And you will know if the pressure regulator is bad or not just by bleeding system........I hope this helps....."Brooks/Metalpoet....."....
Jun 13, 2014 | 2005 Chevrolet Equinox
Have a 99 Toyota camry n brake light is on after changing right front brake caliper
Master cylinder fluid piston has entered into a brake safe mode.
when the high pressure brake system is opened in any way, the brake master cylinder piston reaches to the far end of the master cylinder which trips the brake system warning light.
This brake light condition is due to sudden loss of brake fluid pressure on the right front brake caliper assembly during the replacement.
Left rear brake caliper bleed valve will ned to be "opened" until master cylinder piston travels into the opposite direction which "resets" the brake system warning light.
Dot 4 brake fluid recommened for most, but not all vehicles.
Reference vehicle to owners manual for replacement fluid is replaced under master cylinder brake system cap.
Aug 18, 2013 | 1993 Buick Park Avenue
2001 Silverado 2500 HD Why Rear brakes don't work after I installed new hydro-boost power booster, master cylinder, calipers, and pads. I bled master cylinder before installing, and brakes beginn
Hello Patricia,
Have you checked the master brake cylinder reservoir for brake fluid loss?
I don't suspect the master cylinder as you have replaced it... but am more suspect of a leaking brake line or fitting which should have
been discovered when you had the system bled.
The only time I ever had a rear brake problem with a 2500 series Chevrolet was due to seized rear brake caliper guide pins...as your calipers are also new that is not your problem.
If your brake pedal feels spongy and travels to the floor board you have air in the system, a brake fluid leak or a failure in the power steering system, such as a broken hose, broken power steering pump drive belt, or failed pump, would result in a loss of pressure to both the hydro-boost and steering.
Find more information here:
. Hydro Boost Power Assist Systems Operation Diagnosis and Repair
Jul 23, 2017 | 2001 Chevrolet Silverado 2500HD
How to change rear brakes on a 1997 mercury sable
Replace caliper with old brake pads put 1 bolt in place to hold together while taking a large screwdriver and prying caliper piston so that it compresses piston & block wedge to rear of bracket it should make enough room to install on new brake pads, the other way is to use a large c clamp put 1/4 pice of wood in between c clamp and caliper so you don't damage or Mar the caliper also check YouTube.
Mar 03, 2018 | 1997 Mercury Sable
I have a'90 goldwing,I cannot get brake fluid thru
Your rear brake pedal operates the rear caliper and the front disc. When you tried to bleed the left front caliper you let air into the rear brake system. Bleed the rear brake and front left caliper using the rear brake pedal that should restore the rear (and front) brakes.
Jul 20, 2011 | 1990 Honda GL 1500 SE Gold Wing
Replace rear brake pads
Rear disc brake pads offer better performance and are not as affected by moisture like conventional brake shoe style brakes are. Rear disc brakes are similar to front disc brakes. The main difference is that rear disc brake systems must incorporate the emergency brake system. There are two methods widely used for the emergency brake with rear disc systems. The first system is a brake shoe inside the brake disc that is actuated by the emergency brake lever. The second is a screw style actuator inside the brake caliper. When activated the brake pads are forced into the brake disc and held tightly by the emergency brake lever.
READ COMPLETELY BEFORE STARTING
Step 1 - Identify Rear Disc Brake Components
rear_brake_pads.jpg Rear disc brake assembly includes; rear brake disc, rear brake pads, brake caliper mount and a caliper mounting screw. (Note: Some vehicles do not have the rotor mounting screw.)
Step 2 - Removing the Rear Brake Caliper Mount Bolts
rear_brake_pads_2.jpg To replace rear brake pads and rotors the rear brake caliper needs to be removed. First loosen the rear brake caliper mount bolts and remove them. Turn counter clockwise.
Step 3 - Lift Rear Brake Caliper from The Caliper Mount
rear_brake_pads_3.jpg After the caliper mount bolts have been removed, gently lift the brake caliper from the caliper mount. Inspect the caliper slides; they should move freely in the caliper mount. Remove rear brake pads and hardware.
Step 4 - Removing Caliper Mount Bolts
rear_brake_pads_4.jpg With a socket wrench or other appropriate removal tool, loosen the rear brake caliper mounting bolts. Remove bolts and lift the caliper mount and remove it from the vehicle. Remove the retaining screw from the disc mounting hole. Tap the rotor gently to release any rust that has accumulated between the rotor and bearing hub. Lift brake rotor from wheel hub holding on tightly, using both hands. You do not want to drop the rotor.
Step 5 - Removing Rear Brake Rotor
rear_brake_rotor.jpg Remove the retaining screw from the disc mounting hole, tap the rotor gently to release any rust that has accumulated between the rotor and bearing hub. Lift brake rotor from wheel hub, hold on using both hands and do not drop.
Step 6 - Install New Brake Rotor
rear_brake_rotor_2.jpg Check the new rotor against the old brake rotor to make sure they are the same size. Clean the mating surface on the wheel hub before the new brake rotor is installed. Reinstall rotor retainer screw.
Step 7 - Reset Rear Brake Caliper
rear_brakes_7.jpg Before new brake pads can be installed, the rear brake caliper must be reset. The reset tool winds the piston back into position so the new brake pads will fit. This style of brake caliper will not compress with a clamp tool; it can only be reset with the proper reset tool.
Step 8 - Reinstall Rear Caliper Mount and Install New Rear Brake Pads
rear_brake_rotor_3.jpg After the caliper has been reset, reinstall caliper mounting bolts and make sure the bolts are tight. Then match up the old brake pads to the new brake pads. They should be exactly the same except, of course; the old ones will be worn out. Check the new brake pads for proper fit and install any brake hardware that is required.
Step 9 - Remount Rear Brake Caliper
rear_brake_rotor_4.jpg Reinstall the brake caliper, align brake pad hardware and reinstall caliper mounting bolts. (Note: align the rear peg of the brake pad to the groove in the caliper piston.) Recheck and retighten all caliper and caliper mount bolts. Bleed brake system to relieve any air in the system. Before driving the vehicle, push the brake pedal down and let it up slowly. This operation forces the brake pads to travel to the brake rotors. DO NOT DRIVE VEHICLE until proper brake pedal operation resumes. When test driving vehicle listen for any unusual noises during the operation of the brakes.
WARNING! Always have the vehicle under inspection on level ground, in park with the emergency brake on. Always wear protective eyewear, gloves and necessary clothing before inspection or work begins. Never crank an engine over when anyone is near the battery or engine. Always have an operational fire extinguisher close by, obey all first aid instructions in the event of an injury. Never stand in front or behind a vehicle when cranked over or running. When engine is cranked over keep hands and clothing away from rotating components. Never move a car without proper brake pedal operation.
Jun 01, 2010 | 1995 Saab 900
98 harley davidson rear brake assembly for a fat boy
The rear brake system consist of a rear brake master cylinder, a metal line that has a tee in it for the rear brake switch, a rubber brake hose and a rear caliper.
I'm not sure what you are wanting to know. The rear brake caliper is held into the rear caliper bracket by two bolts. Remove the bolts and the rear caliper will lift off of the caliper bracket. With the brake caliper off the bracket, notice the position of the pads and especially the stainless steel anti-rattle clips. When you replace the pads and clips, make sure you get them in correctly.
Now, you'll have to compress the piston back into the caliper. To do this use either a large pair of slip joint pliers or a large C-clamp. Use a rag or something to protect the paint on your caliper. Carefully slid the caliper back down over the pads while not disturbing them. Install the two bolts and torque them to 25 foot pounds.
You brake systems, both the front and the rear, take type DOT 5 brake fluid as best as I can remember. Harley has changed the type of brake fluid but I cannot keep up with the year model. It should tell you on the tops of the master cylinder.
Extreme care must be taken whenever working on brakes. Make sure they work properly. Failure to test the brakes for proper operation prior to riding the bike can result in sever injury or death.
Apr 09, 2010 | 2000 Harley Davidson FLSTF Fat boy
2001 kia sportage soft brake pedel still doing a complete brake job same as before changing the calipers/pads/ shoes /master cylinder /brake cylinders rear/ bleeding comp. system ? ANY HELP .yet the low...
hi from the uk have had this problem on a customers car b4 who had replaced frot calipers and pads and pedal went to floor on inspection of caliper i found that the steel spring clip that fits into two holes in the front face of caliper and must also locate behind the caliper carrierbehind two lugs was fitted incorrectly it had been fitted behind the outer pad resulting in when brake pedal off ?the caliper being floating type as it is known because it is fixed by two screw pins/bolts and moves on these pins/bolts as pads wear ? what happens is the spring fitted wrongly ? actually pushes against the outer pad and as a result the caliper piston is pushed back into its cylinder slightly as it moves on the locating pins/bolts resulting in pedal going to floor on 1st application but if pumped ? some brake pedal force is felt but is lost again when pedal released ? so try this ? remove the steel clips from both front calipers that retain caliper to carriers then press brake/pump pedal ? if as suggested above works? your pedal should pump up and remain ok when you release and still be firm when re applied ? all above is what i found on ford ford but many other models use similar calipers and spring locating recheck how this spring should locate hope this helps ? good luck
Mar 19, 2010 | 2001 Kia Sportage
I need to know how to bleed the brakes on a 1999 chevy blazer
Start from right rear, then, left rear, right front, left front. Fill master cylinder. Have helper sit in car, have helper hold brake pedal down. open bleed screw. fluid and air comes out. close screw. release brake pedal. Continue until no air comes out. Move to next wheel. Keep an eye on master cylinder fluid level after each wheel.
Mar 27, 2009 | 1999 Chevrolet Blazer
Bleeding abs brakes
Try using a pressure bleeder. It will force the air out. Works every time.
Nov 08, 2008 | 2001 Ford Mustang
Halonet 99-05 BMW E46 3-SERIES 2/4/5DR, CONVERTIBLE: 318i, 318is, 318ti, 320i, 323i, Logo
1,507 people viewed this question
Top Halonet Scuba Diving & Snorkeling Experts
Tom Chichester
Bill Boyd
Marvin
Marvin
Are you a Halonet Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
