SOURCE: HP Pavilion dv2000 Screen.
the lcd lamp driver (inverter is likely bad)
inverter provides the high voltage that the lamps need.
as it heats up it has the symptoms you describe.
easy to replace.
I see them on ebay for around 30.00
SOURCE: hoow to install a dv2000 hp pavilion dvd rw drive (internal)
Remove the Phillips PM2.5x7.0 screw (1) that secures the optical drive to the computer
Insert a thin tool, such as a paper clip, into the media tray release hole (2). (The optical drive media tray release from the optical drive)
Use the media tray frame to slide the optical drive (3) to the left.
Remove the optical drive.
You can download the complete manual here:
http://h10032.www1.hp.com/ctg/Manual/c01035657.pdf
SOURCE: dv2000 laptop webcam
1) Reinstall the Webcam Drivers in the Notebook :
Webcam Drivers for XP :
ftp://ftp.hp.com/pub/softpaq/sp35001-35500/sp35414.exe
Save the Drivers in the Notebook and double click the downloaded file to install the Webcam Driver.
Webcam Drivers for Vista :
ftp://ftp.hp.com/pub/softpaq/sp34501-35000/sp34746.exe
Remember to restart the notebook after installing the Webcam Drivers.
Now, download the Cyberlink Youcam software from HP which is integrated with latest Notebooks to use the webcam with :
ftp://ftp.hp.com/pub/softpaq/sp39001-39500/sp39372.exe
You can use the instructions in the link below to test the webcam using Youcam application in Vista:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01414839&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
You can also try this application to access your webcam :
http://www.yawcam.com/
Using webcam with.....
AIM Video chat:
http://www.ucalgary.ca/it/help/articles/networks/videoconf/aim
Yahoo Video chat:
http://www.ucalgary.ca/it/help/articles/networks/videoconf/yahoo
MSN Video chat:
http://www.bus.umich.edu/Technology/WebServices/DesktopVideoConferencing.pdf
Windows Live messengers:
http://www.ucalgary.ca/it/help/articles/networks/videoconf/livemessenger
Skype Video chat:
http://www.ucalgary.ca/it/help/articles/networks/videoconf/skype
Hope this helps..
SOURCE: XP on HP Pavilion dv2000
First of all, this Notebook is installed with SATA Hard Drive and the drivers for the SATA Hard Drive will not be available with retail versions of Windows XP by default.
I recommend you to try using different OEM versions of XP to install in your Notebook which should work.
Since the Notebook is preinstalled with Windows Vista, the XP Drivers for this Notebook are not directly available from HP.
I had searched some for you which should work.
Download the Drivers one after the other and save them with the name along with the Softpaq Number like the example given below :
Microsoft UAA_33566.exe
So that it will be easier for you to save them and identify.
Save the drivers in one location in the Notebook and double click them once the download is completed.
Make sure that you install the Microsoft UAA Drivers before installing the Audio or Modem Drivers.
Make sure that you install them in the same order I had provided them below :
You need to download the Intel Chipset Drivers for your Notebook from the link below :
http://downloadmirror.intel.com/16023/a08/infinst_autol.exe
Microsoft Universal Audio Architecture(UAA) drivers for High Definition audio :
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33566.exe
Conexant High Definition(HD) audio :
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
As the Notebook is installed with Intel graphic Card, you need to download the Drivers for the same from the link below :
http://downloadmirror.intel.com/16944/a08/win2k_xp14363.exe
Download the Ricoh 5-in-one Card Reader Driver from the link below :
ftp://ftp.hp.com/pub/softpaq/sp37501-38000/sp37712.exe
Download Intel PRO/Wireless Drivers from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34489.exe
As I am not sure whether your Notebook is installed with Intel or Realtek Ethernet card, I am providing both the drivers:
Intel Ethernet Drivers :
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33574.exe
Realtek Ethernet Drivers :
http://drivers.softpedia.com/progDownload/Realtek-RTLRTLRTLRTL-Driver--WHQL-Download-33009.html
You can also try downloading the Marvel Youcon Ethernet Drivers if any of the above provided drivers did not work :
ftp://ftp.hp.com/pub/softlib/software10/COL24713/gs-63707-1/Marvell_Yukon_LAN_Driver_6.36.0.0.exe
Downlaod Conexant HDAUDIO Soft Data Fax Modem drivers from the below weblink :
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33890.exe
Download the HP Quick Launch Buttons drives from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp38501-39000/sp38688.exe
Download the HP Pavilion Webcam Driver from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33544.exe
Download the Alps Touchpad driver from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33751.exe
Finger Print Reader Driver :
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32869.exe
Hope these helps...
