I have the disk but it will not open in Windows 10.
Try running in compatibility mode?
https://help.ea.com/en/article/running-a-game-in-compatibility-mode-in-windows-10
For all types of power window problem and power windows not working,i suggest you to go through the help links given below.Click the link to go through its procedure to troubleshoot the problem :------
driver side power window problem?
http://technoanswers.blogspot.com/2011/06/driver-side-window-problem-on-mercury.html
Driver side power window
wont go up?
http://howtobyme.blogspot.com/2011/10/driver-side-power-window-wont-go-up-on.html
Power window problem
http://repairhelpcenter.blogspot.com/2012/01/pontiac-grand-am-power-window-not.html
rear door or window will
not open ?
http://technoanswers.blogspot.com/2011/06/rear-door-or-window-will-not-open-on.html
How to remove door panel, door window motor and regulator ?
http://technoanswers.blogspot.com/2011/05/how-to-remove-door-panel-door-window.html
Power windows not working after car wash?
http://howtobyme.blogspot.com/2011/11/power-windows-not-working-after-car.html
---------power locks, power window and power mirror not working?
http://howtobyme.blogspot.com/2011/09/power-locks-power-window-and-power.html
All power windows not working?
http://howtobyme.blogspot.com/2011/09/all-power-windows-not-working-on-2003.html
How to remove window motor and regulator on Volkswagen Car?
http://howtobyme.blogspot.com/2011/09/how-to-remove-window-motor-and.html
-------------Complete Diagnosis & Testing Power Windows?
http://repairhelpcenter.blogspot.in/2012/02/diagnosis-testing-power-windows.html
How to replace power window
motor in car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-power-window-motor-in.html
HOW TO REPLACE A POWER WINDOW SWITCH
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-power-window-switch.html
How to Replace a Window Motor
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-motor.html
HOW TO REPLACE A WINDOW REGULATOR WITH MOTOR
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-window-regulator-with.html
HOW TO REPLACE WINDOW RUN CHANNEL SEALS
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-run-channel-seals.html
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-regulator.html
-----------This will help.Thanks.
Driver side power window wont go up?
rear door or window will not open ?
How to remove window motor and regulator on Car?
How to replace power window motor in car?
Number 21 is for the door lock fuse and relay, its a 10 amp fuse.
Number 7 is for the body control module, its a 10 amp fuse.
The fuse panel is under back seat.If all fuses checked out ok,then its faulty drivers door module called as DDM.
Door ajar light stays on?
http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
