Washing Machines Logo
d
dale edwards Posted on Dec 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm getting a Lr error code and then the machine stops working what do I do?
Model #nah6800aww amana front loader washing machine I get a error code Lr come up after starting and it stops filling and working. what does Lr code mean
Kaye Day
Level 3:
  • Master 744 Answers
  • Posted on Dec 01, 2015
 Kaye Day
Master
Level 3:
Answers
744
Questions
Helped
223208
Points
13385
Why is my Ignis front loader washing pump running continuously and showing E12 error code
Please, consider getting a users manual, and trouble shooting guide from https://manuall.co.uk/household-appliances/washing-machines/ignis-washing-machines/. The Error code can be decoded. Machine model will be needed. Continuously running pump would an indication the timing mechanism is not advancing. Sensor problem perhaps.
Amana washer making a grinding noise when draining and getting ready to spin Model # NAH6800AWW
hi,
sounds like the couplers going, if its a traditional top loader, the coupler is in between the motor and the transmission and are meant to shear off to protect the machine from damage, overloading. they dont last forever. once you get the motor off the part is right there..
if its a front loader check the belt teeth.
jm
I have a Amana tandem 7300 front loader washing machine. It's stopped working nothing's happening except the display lights. Stopped in the middle of the wash cycle is there a reset button? Offbalanc
The only reset is to unplug the machine from power for about 5 min's and if that fails you may need to replace the washer timer control board.
My Amana washer model#NAH6800AWW will not fill with water during rinse cycle.
Check cold water coming or not if you can check volts check volts at fill valve . if power there . change fill valve
Posted on Oct 08, 2017
Amana tandem front loader.model number
That's an F8E1 error. It means you are experiencing long fill times. Check your water and associated hoses coming in, also try to clean out the screens on the water inlet valves.
Lr code went into service mode but wont respond to commands model #fav6800aww
Tom,
The LR error code can be a tough one to troubleshoot but I'll see what if any help I can be.
The LR code stands for Locked Rotor.
If you Power Cycle the 120VAC to the machine will the error code clear?
What cycle was the machine in when you took the error code wash, spin?
If you remove the front panel and with the 120VAC power cord removed from the service outlet can you rotate the Clutch Pulley CCW (Spin direction) or CW (wash/agitate) direction.
Sounds like you have the FAV6800A/FAV9800A Service Manual.
Let’s see if the drive system is free and not locked up…………Rich
1helpful
2answers
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Front lader washer maytag neptune
check the drain pump for a foreign object that maybe stopping the impellar wheel from turning.to remove the water use a shop vac attached to the drain hose to get all the water out
Top Amana Washing Machines Experts
Virgil Watts
ZJ Limited
ZJ Limited
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
