Golf Logo
E
Erv casper Posted on Nov 30, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why doesn't our Melex golf cart start after replacing batteries.
We removed six 8 volt batteries which were bad. Replaced them with six new 8 volt batteries. The lights horn and backup horn all work but the cart does not start. Help!
Danny Kuhlmann
Level 3:
  • Master 1,443 Answers
  • Posted on Dec 01, 2015
Danny Kuhlmann
Master
Level 3:
Answers
1443
Questions
Helped
262336
Points
4794
Sounds like you have either a relay or computer that is bad, needs to be serviced
My golf cart has six, 6 volt batteries connected in a chain, positive to negative throughout. Can I connect an auxiliary light of some type to this power source?
the cart is wired for 36 volts operation so you would need a 36 volt bulb
or
you could put the wiring for a 12 volt bub across the terminals of 2 batteries so the negative wire will be on a negative terminal of the first battery and a fused positive wire will be on the positive of the second battery
the batteries are connected in series so the sum total of the voltage is the sum of all of the batteries
by selecting 2 batteries in series you are using the sum voltage of 2 batteries
Nov 24, 2017 • Golf
1helpful
Six 8 volt batteries in a golf cart show being ba the golf cart runs as same good bateeries
You load tested each battery? Can't be bad if cart runs good.
Oct 03, 2017 • Golf
My cart has 6 8volt batteries that are dead my manual shows 4 12 volt batteries should I replace the 6 8 volt with 4 12 volt batteries
make sure that they are in fact 8 volt batteries
You can replace them with 6 by 12 volt batteries as the end voltage (48 volts ) is the same
Mar 22, 2016 • Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 • Golf
Wiring diagram , melex golf cart,model 212
I have a melex mod ha18cm and batteries are charge and its getting spark but not starting what should i do ?Also all the wires are connected .
Want to connect electric lights to ez-go electric golf cart. It is a six battery system and I want to simply add a front light and rear red light.
You said you have 6 batteries. Are they 6 volt or 8 volt? Hint-- 6 volt has three holes in the top and an 8 volt has 4 holes on top of the battery. Battery manufacturers recommend the use of a voltage reducer wired to the whole bank. This take the 36 or 48 volts down to 12 volts and is regulated. this is recommended so as not to stress just 2 batteries. If you have 6 volt batteries, you can use any 2 that are wired in series.
Top Golf Experts
Kardoc
ADMIN Andrew
ADMIN Andrew
vince
Are you a Golf Expert? Answer questions, earn points and help others
