Question about Life Fitness 9100 Next Generation Remanufactured Treadmill
Lifefitness 9100hr treadmill cut out
Hi i have 2 lifefitness 9100hr treadmills and one of them every so often cuts out and resets the whole screen! It may sometimes work for the entire workout and go days without a fault and then other days it can cut out after 1 minute or 10 minutes. It seems that when you tap the emergency stop button a few times it works fine again until next time it decides to cut out. Any ideas what this could be? Thanks
  • Anonymous Mar 17, 2014
    The display on my treadmill looks to be working. However, it does not respond or turn on when I push buttons on the display.
  • Anonymous Mar 20, 2014
    Screen has recently been replaced which we believe has caused the buttons to be out of sync.
Iv had similar problems, only happened once tho - i switched it on after a few mins it would go off.
iv read to dismantle the stop switch, clean and replace the microswitch. where can the microswitch be found from?
also, is the red stop switch that needs looking at? how can i remove it?
i was wondering on how i can service/maintain this properly, can anyone advise my on how to give this a service.
Posted on Dec 01, 2009
    Problem Solver:
  • 5 Answers
Dismantle stop button, clean and replace micro switch with an original one otherwise open, clean and reassemble all.
Posted on Jul 23, 2009
    New Friend:
  • 59 Answers
As said in the other post clean around and under button making sure to remove any moisture from area. Sometimes if you file the edge of button that is all that makes it stick. Watch out when you reassemble you don't pinch any of the wires as they are very sensitive. Best of luck.
Posted on Dec 01, 2014
I need a a power lead for life fitness 9100hr treadmill
Posted on Oct 26, 2009
SOURCE:
Treadmiill keeps saying waxer needs filled after filling it
please see the cause and remedy and fix it. Please read carefully your section of troubleshooting instr. manual or download
Inspect spray pattern between 8" (200mm) and
16" (400mm).
If not, verify wax nozzle is clean, hoses are not
kinked, wax bag is not empty, or wax is
contaminated.
http://www.sportsmith.net/images/product_support/lifefitness/Treadmills/TR9100/9100 Treadmill Manuals/Service/m05100k
God bless you
Nov 29, 2012 | Treadmill Doctor LifeFitness 9100...
Lifestride 9100HR Power to Buttons but Belt does not start.
yes download from www.fitness.manualsonline.com or www.iconservice.com
However LUBE the deck belt, and test the c.breaker or fuse see the block diagram.
Nov 11, 2012 | L.I. FITNESS L I Fitness Tb1812425p Life...
Life Fitness 9100HR Treadmill won't start
Typically a non start up of any electrical Exercise equipment raises alot of red flags If this treadmill will not start Check the internal fuse MAKE SURE ITS NOT PLUGGED IN!!!! UNPLUG IT FROM THE WALL
2 If there is NO Fuse and you just bought it new Return it for an exchange.
3 Check your wall outlet for less then 5 Bucks you can buy a wall outlet tester that tells you if your Outlet is good Or Bad.4 DO NOT Attempt to service this item on your own the way they make treadmills you have to have a qualified service tech come out and fix it because the risk of serious shock or death is emminent.
May 04, 2012 | Life Fitness Exercise & Fitness
My treadmill life fitness 9100HR won't start
Have you checked the drive belt @ the motor, if it is OK then check the fuse, if it is ok then the brushes in the motor may be worn out
May 04, 2012 | Life Fitness T3 Treadmill with Advanced...
Why does my lifefitness series t screen read immobilized?
I believe the tread has been locked out (safety feature important for clubs) - you can call lifefitness and they will give you the key sequence to unlock it
Sep 21, 2010 | Life Fitness 95Ti Treadmill 95 Ti
My Life Fitness treadmill needs to have the motor control board replaced. A new one is costly, where would I get a used one? We are in Ontario Canada.
if it is a classical model 9500/9500HR/9100/9100HR can take the card to a qualified technician mail, you must open the controller and change the following components: D4015L (2) 2N6507 (2) TIP110 (1) and in the latter case there to change the IRGBC40S.
if you treadmill is the Next Generation you should buy new and can find on sportsmith.com
Sep 04, 2010 | Life Fitness 9500HR Next Generation...
How do i reset the waxer on a 9100 lifefitness treadmill?
Press these buttons:
101–ENTER–
HILL–RANDOM–
FIT TEST.
Program lights come on. Display will scroll toWAX DELAY OFF.
Press speed "UP" or "DOWN"
to toggle to
WAX DELAY ON or OFF.
May 13, 2010 | Treadmill Doctor LifeFitness 9100...
Cant get the lifefitness treadmill T7-0 to work
you may need open up the head board and check the switch.
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Mar 29, 2009 | Life Fitness LifeFitness 97Te Treadmill
Life Fitness 9100 Next Generation Remanufactured Treadmill Logo
1,743 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent_G
Vincent_G
Craig Butler
Craig Butler
Android Man
Android Man
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
