LeapFrog My Own LeapTop LapTop - Violet Logo
A
Anonymous Posted on Nov 30, 2015
MY LAPTOP'S DEAD UNTIL I GET MY SECURITY BACK. HOW CAN THIS BE DONE & HOW LONG?
All instrutments gages go dead until you disconnect battery then it gos back to normal
Without any further information, this problem hints of a security lockout. It also suggests a loose or corroded wire connector, possibly at the PCM, or the security module, if the security module is separate from the PCM.
Hp 250 GB Pocket Media drive having erratic behaviour under Windows 7 (Motherboard ECS G41chipset), Under windows XP front and back USB ports recognize disk as USB 2.0 device - able to read and...
XP is a dead OS.
100% dead. and not supported now. by MS or HP.
but XP needs SP3, or USB will be bad
XP always had bad USB for years until , all patches were done.
The USB on XP are horrible.
you need good USB so all devices are PnP recognized
and negotiated currents (power) is working
and USB2 currents are weaker than USB 3.
and is key to making any motor driven HDD work right.!!
Dead as a door nail and no more security patches ever again.445635a4-18b0-42a5-a249-084bb91c84b0.jpg
The laptop doesn't boot. Its dead. I tried connecting the charger, but it doesn't shows any signs of charging. It doesn't even show the laptop is charging.i.e no led is lit when charger is connected.Please...
Hi.
If it is completely dead check the voltage at power adapter DC contacts using a multimeter.
If there is voltage within 0.5 Volts from specifications, then try starting the laptop with no internal battery. A shorted battery may cause the laptop not starting.
If battery and adapter are OK, then the problem is the DC socket in the laptop motherboard. The laptop must be taken apart and the solder joints soldered back. This is a delicate job and must be done by an experienced repairer.
In some case the whole power circuit or the main board may be faulty. Testing is done reading Ohms at DC socket solder joints on main board (or power board, depending on model).
Regards.
Ginko.
4helpful
3answers
Lights on the bike flash and the bike will not start, can anyone help?
If you have a factory security system with the sensors located inside the key fobs you probably need to replace your fob battery.
My sigmatel s4 has dead. i have activated hispeed sim on it. how can i get back to normal working condition?
Try to swich it on buy taking simcard out & then goto settings & select RESTORE/ORIGINAL setting give security code & its done
2003 chev suburban.battery went dead.replaced battery,now it wont crank and security light blinks
I have ran into this problem many times. Insert the key, and turn it to run. After 10 minutes the security lamp should go out. Turn the key off, and then back to run and let it sit another 10 minutes until the security lamp goes out again. Now repeat this one more time for another 10 minutes until the lamp goes out again. This should be a total of 30 minutes so make sure your battery is fully charged when you start the procedure. After the third time and the lamp going out you should be able to restart the vehicle.
4helpful
My MPC t2300 laptop wom't turn on.
The Transport T2300 has an internal battery that will run the laptop for several minutes after the main battery goes dead. This feature allows you to save your work and shut down safely. If you run the laptop until both batteries are dead, even a brand new battery can't start the unit again. You have to follow this procedure:
1.Unplug power cord
2. Remove any attached periphal components including the cd rom and/or floppy disk module if you have one. Both remove with a push button switch located on the bottom of the unit.
3. Plug in power cord and charge the unit for a minimum of 24 hours straight. 30 hours is better. This whole time will be spent slowly recharging the internal back up battery.
4. Once that is done, unplug power cord again and reinstall any floppy/cd drives. Plug power cord back in now and charge for at least 24 hours again.
If your backup battery is dead, you can't charge the main battery or turn the unit on. The longer you charge, the better. We had one unit here that had to be on the initial battery backup for 72 hours before it finally took hold. Then, one overnight recharge on the regular battery and all was well.
If you need drivers or manuals for the 2300, all are available on cd at [email protected] for around $9.50 including shipping, handling, and owners manual
Top LeapFrog Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a LeapFrog Video Game Console and Game Expert? Answer questions, earn points and help others
