With Power On from the Generator the Projector was switched on. The Bulb did not light up. Red lihgt at "Power" blinked for some time. Then "Power" light became stable RED and "Lamp" light too came on and remained steady RED. Does it mean the Bulb is fused because of the Power from the Generator?
the lamp timer is failing
lamp timer chip is on the lamp housing,is a little chip
you need to reset the timer chip by using a Programmer
select a date of 0 hour..
Our company supply this chip with 0 hours USD15
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
firdt off, did you reset the lamp counter? did you clean the dust out of the projector? it may be overheating as well. if the lamp looks ok, you may have just blown the ballast. try projector doctor online.
Hi
if the status light is blinking red in 4 sec interval it means that there is something wrong with cooling system. you shold check if there is a thermostat failure or if there are any switches that are not turned on. i suggest you to open the device (using screwdriver) and check if there are any switches broken or damaged.
i had pretty much the same problem (one second interval). i took off the cover and there was a broken switch and i just short-circuit it and now it works
