Question about Janome Memory Craft 350E Embroidery Machine w/ FREE BONUS
I am trying to embroidery with the B hoop and the fonts in the machine. In the edit mode it shows that the B hoop is selected but it stays on the smaller hoop. Why?
  • 31 Answers
Did you try switching it off and trying again.
Posted on Jan 17, 2016
    Top Expert:
  • Janome Master
  • 63,027 Answers
It is electronic and has a mind of it's own . contact tech support at janome
Posted on Nov 30, 2015
SOURCE:
Want to do sample on smaller hoop, how do I adjust size to fit?
Hi which machine do you have? There should be an option on your embroidery machine, the screen, showing "edit"
Click on it and select your hoop size there.
Sep 05, 2018 | Sewing Machines
What embroidery hoop does an elna 650p heirloom edition use?
I believe this model is a sewing machine not embroidery. Elna 6005 Heirloom Edition. "Expressive" Line is Embroidery/Sewing. Expressive 860 through 960.
Cheers,
Embroidery Services
San Diego, CA
Jul 07, 2016 | Elna Sewing Machines
Embroidery
When you are editing the design make sure you are actually doing it in the hoop size that you want. It may be that the design has been done in a larger hoop although it does not really require it. I can change the hoop size on my machine. Good Luck!
Oct 15, 2017 | Bernina Sewing Machines
My Husqvarna designer SE embroidery unit keeps giving an error message "install hoop correctly". I've checked everything but can't get around the message. can anybody help ,?
You have probably got the machine set to use a different size hoop. Click on the hoop icon and change it to the size you are using. Hope this helps you.
Aug 04, 2013 | Husqvarna Sewing Machines
Brother PE770 Hoop size programming stuck on small hoop option
Your machine would be able to perform 5 X 8 embroideries. The hoop size on this machine is recognized by the machine itself, depending of the embroidery file size. So it the embroidery is small, it will indicate that the small hoop is needed.
But U can use the large hoop, position the embroidery where U want then perform another embroidery on the sams hoop.
TRICK : the embroidery size exceeds the hoop? reduce it in X and or Y using this function on the machine
Jun 10, 2012 | Brother PE770 Computerized Sewing Machine
Error message - design to big- use multiple hoop embroidery-won't transfer to my machine for a large design
If you can get the Buzz edit software there is an easy fix. Open the design in buzz edit. Under the view tab, show hoop properties and select xl6000 hoop. Then again under the edit tab select all. next under the buzztools tab rotate the design 90 degrees. This usually takes care of the problem, don't forget to save as copy. If it is still too large, shrink the design until you see it fit into the hoop on the screen. Don't shrink it more than 10percent or your stitches will be too cramped. Hope this helps. I use it all the time. Using this you can use designs up to 5.5 x 9 inches
Aug 04, 2011 | Singer Professional Sew Ware Options 2.0...
For the HV #1+ embroidery unit, using the plus hoop and embroider
Hi!
You can find the solution by following these steps-
Slide in embroidery card 21 and companion cassette. Touch Embroidery ON.
Touch FUNC to Program mode, The “E” inside the hoop will appear on the left end of the Program display window. If Plus Hoop programming is desired, touch the rotational arrow E one time and you will see the hoop in the Programdisplay window change into a Plus Hoop with a small arrow pointing to the top portion of the hoop, indicating position 1.
Toward the right side of the Program display window are
F1 S1 M1. F1 = Font style (1, 2 or 3), S1 = Size (1 or 2) and M1 = Menu (1, 2 or 3).
FONT: Select 1. Palace Script 2. Clarendon (block) 3. Kalligraphia
(Note: Programmed letters are always displayed in block)
SIZE: Select 1. Large 30mm 2. Small 12mm
MENU: Select 1. Upper case, 2. Lower case, or 3. Numbers and Symbols—check Program display for upper or lower case indication.
Note: You must select the Font, Size and Menu before selecting the letter desired.
Do rate the solution accordingly.
Thanks
Rylee
Mar 16, 2009 | Husqvarna Viking 1
Quantum XL 1000 Embroidery Frame will not stay secured in place
First is this a hoop that came with it or is it a fits all hoop? if you havent' used this manchine alot for this the hoop my be hard to push down hold the front of the hoop up and push the back down into the slots as you use it it will get easier.
Jan 14, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Janome Memory Craft 350E Embroidery Machine w/ FREE BONUS Logo
638 people viewed this question
Top Janome Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Carolyn Rogers
thinksewfast
Are you a Janome Craft and Hobby Expert? Answer questions, earn points and help others
