Paper LED just blinks white. Just bought and have paper in the right way only printed one photo. Is there a hard reset button somewhere?
There is no such external reset buttons to modern TVs. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
SOURCE: Paper feed problem, then error
SEPARATION ROLLER MAY NOT INGAGE CAUSING THE PAPER NOT TO FEED TO THE FEED ROLLERS THE PAPER DOES NT ADVANCETO THE REGISTION ROLLER THAT SET THE PAPER FO COPY CHECK TO SEE IF THEY ARE CLEAN OR WORN
SOURCE: Canon Pixma MP810 Full Page Photo problem
Check your print settings and run an allignment check.
SOURCE: Light purple cast to black and white prints
Known issue. Use QTR to print bw prints. Works great on my Epson 2200.
http://www.quadtonerip.com/html/QTRoverview.html
SOURCE: flashing led power button on deskjet d2460
try to check your cartridges. Pull it out one at a time then try to see it it stop blinking. Especially cartridges that was refilled. Improper refilling of cartridges causes them to stop responding to your printer and causes to malfunction. this was base from my experience.
SOURCE: paper led light wont stop flashing
Pull the tray out and make sure the back guide is pushed against the paper. The back guide tends to move easily on these models
Yes, just under the power plug there's a tiny hole. Insert a paper clip and it will reset.
it worked ;)
Thank you, the toothpick in the hole worked. :-)
