Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
m
michael belt Posted on Nov 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Are there reset button on the motor
Will not turn on
Claude Kayser
Level 3:
Top Expert:
  • Whirlpool Master 9,098 Answers
  • Posted on Nov 28, 2015
Claude Kayser
Whirlpool Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5066758
Points
28436
Whirlpool duet sport F21 error code fix - YouTube
? 4:39
https://www.youtube.com/watch?v=qQTvBSnEWsI
Feb 22, 2010 - Uploaded by heli400
Also note TROUBLE SHOOTING MANUAL IS TAPED TO THE ...I have replace 6 detergent ben hose 1 motor the membrane on thebuttons .... I've owned the washer for 6 years and I never knewthere was a filter underneath!
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...
? 7:29
https://www.youtube.com/watch?v=SPRqKVE8JfY
Oct 21, 2011 - Uploaded by canyonman1963
I have a Whirlpool Duet MOD GEW9250PWI It's not making any noise, ... only" I've unplugged it and plugged it back hoping it would reset it. ... The service man I use stated it was the motorgoing bad, the smell of ... i checked the door switch, it was fine too i believe. so thermal fuse ... There still is not start up.
Our bosh Maxx 7 varioperfect washing machine buttons are not working Amd showing f:21 error
F21 error on this model of Bosch washing machine pertains to a motor or a control board fault. This can be reset and to reset it turn the appliance knob to the off or reset position (12 o'clock), turn the knob to the 6 o'clock and then press and hold the spin button, then while holding that button turn the knob to 7 o'clock position, continue holding spin button for 15 seconds and then turn the knob to off. After a minute turn it back on, if the error code is still there then it means that the motor or brushes in the motor should be replaced, though it is always better to replace the motor assembly completely.
How to fixed a error code E43 of washing machine Siemens
This is related to the motor, and may be that the motor needs new brushes the Tacho (feedback mechanism) is broken, wiring or the motor control board. Most likely for a 6-7 year old washing machine is the brushes.
However, after changing them, you still need to reset the machine
  1. Turn off the machine (dial to 0)
  2. Open the door
  3. Turn on the machine on first program
  4. Close the door
  5. Turn off the machine
  6. Turn on the machine on the "six-o-clock" program, which is centrifuge
  7. Press the "option down" button and keep it pressed (This is the button left of the display)
  8. Turn the dial to "seven-o-clock" (empty/pump out program)
  9. Release the "option down" button
  10. Turn of the machine
This should reset the machine, and if everything is allright, it should work. If it does not work after changing the brushes and resetting it, something else is wrong, most likely the motor control board, or if the motor.
Does the pump on my motor have a reset button
There are no reset buttons on motors.
How do you turn the pump on/off ?
My Bosch Logixx 8 sensitive won't work and shows the code: F:43
Bosch Logix with error code F43 has "a motor fault".
You can reset the error code by the follow steps:
1. Turn the appliance knob to the off or reset position, 12 o'clock.
2. Turn the knob to the 6 o'clock position.
3. Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position. Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off
When your turn it back on it should have cleared the error code
Check motor connector block
Check wiring
Check motor carbon brushes
Check tacho connections
Check motor
5helpful
F21 what can I do? Please please
Hi
F21 error in your Bosch washer relates to a motor or a control board fault. This can be reset and to reset it turn the appliance knob to the off or reset position (12 o'clock), turn the knob to the 6 o'clock and then press and hold the spin button, then while holding that button turn the knob to 7 o'clock position, continue holding spin button for 15 seconds and then turn the knob to off. After a minute turn it back on, if the error code is still there then it means that the motor or brushes in the motor should be replaced, though it is always better to replace the motor assembly completely. Hope this helps...please post back for further assistance.
Daniel
9helpful
F 21 is flashing not got a reset button no lights are lighting up
F21 is a motor or control board fault.
This also can be caused by voltage spikes or surges; to reset it...
Press and hold the spin button.
While holding it, turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds.
Release the button.
Turn the knob to off.
If the problem continues then check the motor.
6helpful
Insinkerator stopped working. Cutting plate rotates freely. tHE RESET BUTTON IS STUCK IN THE "ON" POSITION.
If the reset button is stuck in the on position and can not be reset, the motor has an internal overload and will need to be replaced. Turn the power off to the motor via switch or circuit breaker, let it cool for awhile, the hit the reset button again to see if it resets. If it does, turn off the power at the breaker and leave it off. At this time, you need to dislodge a jam on the rotary vane that shreds the waste, there is something most likely stuck on the vane, causing the motor to overheat. There should be an allen wrench socket area in the middle of the underside of the motor housing, use an allen wrench and turn the motor manually back and forth, to release the jam. Again, be sure the power is OFF!!!
Dryer wont turn on
No reset button. If you hear a groaning noise when it tries to start, the motor has failed and you need a new motor or dryer.
31helpful
2answers
Error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
Is there a reset button?
THERE IS NO RESET BUTTON ON THE WASHER, ONLY THE OVERLOAD AND THERMAL LIMITER ON THE MOTOR. SOUNDS TO ME LIKE THE MOTOR IS BAD, BUT CHECK TO MAKE SURE THAT ALL THE PULLEYS TURN FREELY ON THE BOTTOM OF THE MACHINE BEFORE CONDEMNING MOTOR.
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
