Clearing the error code l4-30 on a sharp mx-6201n
Is that a L or I could not find I in the service manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
SOURCE: Sharp AR 5316 E photocopier error clearing
try to cancel it by pressing: #-interrupt-C-interrupt simultaneously, then when the panel goes off input 16 then press the COPY KEY <> The machine will restart automatically. if U2 still remains.. try to replace the mainboard.
SOURCE: sharp arc 270 error code l4-04
Possible bind in one or more of the developer units. Replace as needed.
Sec. 11 Page 11-61 it talks about Paper Feed Drive Motor, it is the
same motor as the Black Developer Drive Motor.
For L4-04 swap those two motors around to troubleshoot bad motor
SOURCE: How do I clear machine error code E04-01 on a
How do I clear machine error code E04-01 on a Panasonic DP-3030 photocopier?
Hi
Error E7-06 means Image data decode error. This appears due to Image expansion error. It has been caused due to MCU PWB abnormality or USB cable trouble
Try using a different USB cable. If this doesn't help then try the reset procedure---
Sharp ram clear -- Press function 9 * 8 # 7 then # or * until display reads memory clear, then press start. Note the other maintenance mode options displayed on the screen when pressing # or *.
Hope this helps...
Daniel
