SOURCE: HP iPAq HX4700 wont sync
This is a VERY common problem with these, and HP is aware of it.
You can try these steps as per HP:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=420534&prodTypeId=215348&objectID=c00595366
SOURCE: Sync Manager Problme with Vista with LG CU500
The problem is a driver issue. It is strictly a LG/Verizon problem, and not Windows. What you should is hook up your phone your computer LG USB cable and using the Music Essentials CD-ROM.
Install the latest version of BitPim where you can find at http://www.bitpim.org/ .
"I hooked up my phone to my computer via the USB cable, and opened BitPim. Much to my dismay, bitpim did not find the COM for the LG Modem".
However, Vista popped up the window in the taskbar telling me that new hardware was detected but could not be installed. I went to Start > Search > Device Manager
Once the Device Manager is opened up, you should see an unknown hardware profile for the USB cable/phone. In my case, Vista seemed to recognize the fact that it was a LG USB Modem, but didn't have the driver. Anyway, right click on the unknown driver and select "update driver software." Surprisingly, Vista will tell you it found a driver. Unfortunately, when when you go to install the driver 2 new unknown drivers will appear.
To fix the 2 unknown drivers, all you have to do is insert the VCAST Music Essentials disk into your disk drive, and point Windows in the direction of the files for the drivers on the VCast Music Essentials CD (in my case, the D: drive).
Windows finished the install, and from their BitPim recognized the cable on COM5.
That should work.
SOURCE: PC SYNC OF PHONEBOOK
I CAN NOT SHARE DATA TO MY PC FROM MY LG MOBILE PHONE RD8000 RELIANCE.I PLUGED USB PORT IN MY PC,
THE PC ASK ME INSTALL SOFTWARE CD,WHEN I PURCHASE MOBILE THERE IS NO CD ONLY DATA CABLE,I GOT.
KINDLY GUIDE ME. &REPLY ME
PGOWRISHANKAR,
CHENNAI.
[email protected]
SOURCE: forgot how to sync my
Hold the up volume and the talk button (the one on the side of the ear piece) down until the status light flashes red then blue. This places the headsead into pairing mode.
SOURCE: i forgot my code that unlocks my metro pcs zte phone
You can try all zero's (Example: 000000, 0000). Now since your device already has a custom unlock code, more than likely you will need a customer service representative of MetroPcs to assist you, where such information can be accessed.
I reset my ZTE cell phone and I also Sync my ph and it does not recognize my Gmail and I did this over three-time
