Question about Kitchen Selectives Coffee Makers & Espresso Machines
Looking for paper filters for kitchen selective one cup brewer
  • Kitchen Sele... Master
  • 26,397 Answers
You don't need paper filters it has a 'permanent filter'. That means it has a fine mesh nylon filter that you rinse and re-use.
Kitchen Selectives Single Serve Coffee Maker Permanent Filter Mug Included
Posted on Nov 28, 2015
SOURCE:
Keurig troubleshooting
if off warrenty these machines are basically throw away. sorry
Jul 20, 2014 | Keurig Ultra In Home Single Cup Brewer...
Coffee comes in different amount when I select the same size button .
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Mar 18, 2011 | Kitchen Ranges
I need to know how to descale the unit.It is flashing another filter looking picture at bottom left of display. It is not filling the cup with water any more.
Check out this tip about how to descale your Keurig coffee brewer
How to Descale your Keurig Coffee Brewer
heatman101
Mar 14, 2011 | Keurig Platinum B70 Coffee Maker
I'm only getting 1/2 cup of coffee each time I brew. I've changed the filter. What should be my next step?
Sorry to read about your issue.
Their is no filter on the b40 so i dont know what you mean about that.
you model may have one or two brew size 10oz and 8 oz take a kitchen measure cup and check it
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 21, 2010 | Keurig Elite B40 Coffee Maker
We bought a Kurig Mini at this past Christmas. The machine worked great for about 4 months then the Kcups started exploding in the machine and coffee grounds would go into the brewed cup. Then the...
Mine has been doing the same thing.  I alkso received one at Chriustmas and it worked great for a few months.  Below is the answer I received from Keurig:
It is possible that the needle that penetrates the K-Cup has become clogged.  Please follow these simple steps to clean it:
Turn off the brewer and unplug it.
Reach under the nozzle (where the coffee comes out) and press up on the bottom of the funnel.  The K-Cup holder will pop out.
Separate the K-Cup holder into two pieces.  The top piece of the K-Cup holder is where the exit needle is located.
Use a paper clip to clear the exit needle by putting the paper clip in the tube on the underside of the holder. Be careful, the exit needle is sharp.
Wash the K-Cup holder with soap and water, rinse thoroughly.  Also make sure the drawer is clean.
Put K-Cup holder back into the drawer, making sure it snaps into place.
Plug the brewer in and turn on.
Run two cleansing brews (brew without a K-Cup) through the machine, and then brew a cup of coffee.
If you still find grinds in your coffee, it would be best for you to talk to a representative to help troubleshoot your problem and discuss your options.  This could be caused by too much pressure sealed inside the K-Cup or the filter alignment may be off.  Please contact our customer service department at 1-866-901-BREW (2739).  Representatives are available 7 days a week from 7 a.m. – 12:00 Midnight EST to assist you.  Please have the serial number of your brewer available for when you call.
The serial number for the Mini is located on the bottom of the brewer on a silver sticker.
For the Classic, Ultimate and Select, is located on a sticker behind the drip tray.
For the Elite, Ultra, Special Edition and Platinum it may be located either on the bottom of the brewer on a white sticker or, behind the drip tray.
Sincerely,
Briana Keene
Keurig Customer Service
At Home Division
(866) 901-BREW (2739)
csrah@keurig.com
Aug 25, 2010 | Keurig B30 Mini Coffee Maker
I need a new replacement k-cup portion pack and filter assembly
replacement parts are hard to come by but the portion unit can be bought on amazon.
My filter was metal, so I'm not sure about something cracking...
ebay has many people selling broken units... good for parts...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
May 05, 2010 | Keurig Elite B40 Coffee Maker
Keurig B60
Check the needle inside the k-cup holder to ensure it is not clogged. You can completely remove the k-cup holder by pushing up from the bottom (where it dispenses into your coffee cup). Then rinse it out with hot water using your kitchen sink sprayer. The manufacturer also recommends inserting the tip of a small paper clip into the needle to push out any debris if needed. Then replace the k-cup holder by aligning the arrows and snapping it back into place. Next try to brew your regular cup of coffee and see if that fixed the problem. Hope that worked for you...Best of luck!
Aug 29, 2009 | Keurig B60 Coffee Maker
Where to buy paper filters? 10 - 12 cup are to small
MRCA8E is the discontinued filters for the MRCTB brewer. I'm on the hunt for suitable filters too....
Dec 06, 2006 | Mr. Coffee MRCTB Coffee Maker
Coffee Makers & Espresso Machines Logo
85 people viewed this question
Top Kitchen Selectives Coffee Makers & Espresso Machines Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Terry
Terry
Are you a Kitchen Selectives Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
