Samsung UN55ES6500 55 Inch 3D 1080p Smart TV LED LCD HDTV Logo
a
alicia king Posted on Nov 27, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The Samsung app is not in my list of apps, what do I do?
Mr.Mike
Level 3:
  • Master 580 Answers
  • Posted on Nov 27, 2015
Mr.Mike
Master
Level 3:
Answers
580
Questions
0
Helped
195909
Points
1906
You can search for the apk, "Samsung App Store apk"
You can check my link, there is another link within it that may still be valid.
the important thing when searching for this apk is try and download it from a place that you can trust,
you may need to change the setting in your phone that allows you to install applications from unknown sources.
Good luck and thanks
Questions? Just ask!
How do you delete programs that you don't what on your phone galaxy 5
Settings, aplication manager, choose program fRom the list, uninstal
tip
How to Close Apps on a Samsung Galaxy
1) Go to the Home screen of your Samsung Galaxy device.
2) Press and hold down the "Home" key on your device. This action will display a list of all applications you have recently accessed.
3) Review the list of applications to determine which apps you want closed.
4) Tap and drag each app you want closed to the right or left. The apps you drag off-screen will automatically be closed.
  • If you want all apps closed, tap on the "Remove All" icon located at the bottom right corner of your screen.
1helpful
Samsung Galaxy S7Edge owners? I need some advice please : Stock or Root? The bloat is killing me, my battery is just worse & worse everyday, it also makes this random clicking noise now?? Ugh..Any advice/...
well like a lot of phones is to disable apps. Go to Settings apps and scroll over to the all tab for a complete list of your apps. If you want to disable an app simply tap on it and then tap disable. Once disabled, these app won't appear in your primary apps list, so it's a good way to clean your lists up. first click on force stop then disable.
What does screen overlay detected mean with android phone?
Step one: "Screen overlay detected" fix
Find you what apps have permission to draw over the screen. On a non-Samsung smartphone, follow these steps:
  • Open the Settings
  • Tap the magnifying glass at the top right
  • Enter the search term "draw"
  • Tap Draw over other apps
  • Alternative route: Apps> [gear icon]> Draw over other apps
For Samsung users:
  • Open the Settings
  • Then Applications > Application manager
  • Press on More > Apps that can appear on top
Step two
You will find yourself in front of a list of apps that have permission to use floating buttons or other screen overlays. Now you need to identify the problem app and temporarily deny it permission to draw over the screen. Here is are some pointers on how to identify the app that's causing trouble:
  • Do you see an app bubble on your screen? If do, this app is almost certainly the cause. Either you hide the app bubble or disable the app in the list
  • Do you have an app installed that changes the colors on the display or adjusts the brightness?
  • Reportedly, Clean Master can be a trouble maker. If you see Clean Master in the list, disable it
  • If there's no obvious cause, disable everything
Step three
Now you can try launching the app again, and it should request permissions without the "Display overlay detected" error getting in the way.
For Samsung users: We have also received a report that suggests the one-handed keyboard setting could be the root cause. Deactivate it by going to Settings> Advanced features > One-handed operation.
Step four: reactivate screen overlays
In order for the app(s) that you have disabled in step two to work again, you need to re-enable its overlay permissions. If you turned off all apps, it might be worth considering only reactivating those apps that you actually use.
This is a rather inelegant workaround, but it's the best we have until Google makes the necessary changes to prevent app overlays from interfering with permission dialogues.
Has this guide helped? If you are still experiencing the error after following our guide, leave a comment, so we can try and address the problem.
Samsung Galaxy Tab 3 tablet
weird. Have you tried hitting the multi task button next to the home button that lets you jump from recently opened apps? I would try this to see if it will list an app that is opening and playing the cheezie music. If it lists the app, go to your settings and uninstall it if you don't need it or go to the app and find the setting that keeps doing that.
If that doesn't work, I would go though downloaded applications under settings and see if there are any demo apps installed, or maybe clean out the apps you don't use anymore and see if it fixes it. It will at least speed up the tablet.
How do you retrieve a disable app on Samsung ipad
go to setting than app manager you will find the app their.
How do i know if i have play store on my samsung s 3
Go to Menu Select Apps in List View Scroll down the list of apps and if you have Play Store, you will have an app that says PLAY STORE. If you do not have it, download it. Go to Google Play Store
How do i turn my list app into grid app on a Samsung galxey phone plz
when in app list press the menu button and select grid
Bought apps for samsung focus but there are no icons on the phone. How can I troubleshoot this problem?
Depending on the type of app you bought it may be located in the games hub or the general app list.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
