Heating & Cooling Logo
Tim Weiss Posted on Nov 26, 2015
I have a Febo Flame Electric Fireplace Model#SF-103-23, Insert Prod.#12in-23-051.The Light bulb is burned out that gives the flame effect. How do I replace the bulb, and where do I find a bulb?
tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 • Heating & Cooling
Febo Flame Fireplace ZHS-30. Is there a replacement insert available for Febo Flame model number 18IN-30-122 please?
Question edited for clarity.
Are you aware of the recall on it for dangerous electrical connectors?
L G Sourcing Recalls to Repair Electric Fireplaces Due ...
U.S. Consumer Product Safety Commission (.gov) https://www.cpsc.gov > Recalls > L-G-Sourcing-Recall...
Dec 9, 2020 - An insert inside the cabinet simulates a wood-burning fire and provides heat. "FEBO Flame Electric Fireplace Model Number ZHS-30-A" is ...
https://www.pennlive.com/life/2020/12/electric-fireplaces-sold-at-lowes-years-ago-recalled.html
This is the Parts List Manual for a different model, but contact details are on the first page.
https://www.manualslib.com/manual/1735770/Febo-Flame-F18-I-008-018c.html#manual
Nothing on the secondary market or from distributors
https://www.google.com/search?q=Febo+ZHS-30+replacement+insert
Sep 10, 2023 • Home
2answers
I NEED A REMOTE FOR FEBO FLAME ELECTRIC FIREPLACE ZHS-23-B
From them direct
  • 1-877-355-3326
  • (925) 820-8476
  • 381 Hartz Ave. Suite D
    Danville, CA 94526
  • PO Box 189, Danville, CA 94526
Electric Fireplace ' Febo International
febointernational.com > products
We offer wall-mounted fireplaces, home entertainment systems, and bathroom vanities. ... Enjoy your fireplace with heat or flame only, or with heat and flame combine. ... optional stand and remote control included (1 CR2025 battery included) ..
What kind of a light bulb is needed for the febo flame electric fireplace?
Flickering flame fires generally use a fairly ordinary tungsten filament incandescent bulb, except the Fireglow bulbs are coated with an amber coloured lacquer. The heat from the bulb causes an upward current of air causing a small "windmill" to turn and cause the light to flicker.
That is the traditional method but ultra modern fires might use a higher-tech solution.
2answers
How do you change a bulb in a Febo flame electric fire place
FEBO Flame Electric Fireplace - YouTube
? 2:12
www.youtube.com/watch?v=o5A-QowBVbs
Nov 24, 2014 - Uploaded by Phatkat Allure De ****
FEBO Flame Electric Fireplace. ... I love my electric fireplace, more of a focal piece it is really pretty. Read more ...
How to Change a Light Bulb in your Electric Fireplace
3helpful
4answers
Electric Fireplace Insert
verify the breaker is on (reset) then power up and verify voltage with a meter, there are safty devices that will keep the unit from energizing other than the switch
Top Heating & Cooling Experts
Paul Carew
john h
