You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.netfor parts, repair service and DIY info.
var experts = [{ avatar:'/Uploads/Avatars/68F2C5C.jpg',userName:'MNfisherman',"memberSince":'January 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'85.7%, 799 votes', userUrl:'/users/mnfisherman',solutions:2295,experience:'
Experience: Have knowledge with just about anything that is electrical, mechanical, or electronical & more!',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/ABF4CAB.jpg',userName:'localwonder',"memberSince":'January 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'90.7%, 1460 votes', userUrl:'/users/localwonder',solutions:2913,experience:'
Experience: I have yrs of experience dealing with many situations.',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/images/icons/noAvatar.png',userName:'avid101',"memberSince":'May 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'85.8%, 264 votes', userUrl:'/users/avid101',solutions:795,experience:'
Experience: Certified Master ASE Car and Truck Mechanic Certified AC mechanic Cert. AWS welder cert. Electrician',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/images/icons/noAvatar.png',userName:'adirondacktr',"memberSince":'July 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'86.0%, 108 votes', userUrl:'/users/adirondacktr',solutions:363,experience:'
Experience: hands on experience,training, mechanically gifted,and favorite reading material is how to fix things',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/4FD9B30.jpg',userName:'venexcsd',"memberSince":'May 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'87.2%, 197 votes', userUrl:'/users/venexcsd',solutions:526,experience:'
Experience: 50 years in the University of Life, plus an electrical engineering and computer background. ',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/579A389.jpg',userName:'benwabnick',"memberSince":'January 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'89.5%, 383 votes', userUrl:'/users/benwabnick',solutions:881,experience:'
Experience: Been working as a computer technician for 10 years and have certifications in A+, Network+ and MCP',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/images/icons/noAvatar.png',userName:'justaskjoe',"memberSince":'January 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'86.8%, 964 votes', userUrl:'/users/justaskjoe',solutions:1787,experience:'
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/5446F1F.jpg',userName:'heavymetal77',"memberSince":'June 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'85.2%, 95 votes', userUrl:'/users/heavymetal77',solutions:311,experience:'
Experience: I have a wide range of experience in many fields.',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/1B34289.jpg',userName:'taran_2005',"memberSince":'November 2008',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'87.9%, 392 votes', userUrl:'/users/taran_2005',solutions:1752,experience:'
Experience: If you have the desire to repair, follow my steps and be happy!!!! ',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/0915BCA.jpg',userName:'komguy',"memberSince":'May 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'89.0%, 177 votes', userUrl:'/users/komguy',solutions:301,experience:'
Experience: I have been a Canon certified warranty repairman for 4 years. Always on top 10 national list.',brandType:0,brandName:'',brandIcon:'' }]
BRAND_ICONS_DIRECTORY = '/images/Brands_24x20/{0}.gif';
var ctrl_experts = new Fixya.TopExperts(experts,$('ancAvatar'),$('imgAvatar'),$('ancUserName'),$('spnMemberSince'),$('imgRank'),$('spnRank'),$('spnRating'),$('spnSolutions'),$('spnExperience'),$('imgPrev'),$('imgNext'),$('imgBadge'),$('spnBrand'),$('ancRating'),$('ancSolutons'));
ctrl_experts.render();
