SOURCE: Sharp AR-287 Copier error code H5-01
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
SOURCE: error code h5-01
Hello sir; the paper exit sensor get stock, just put back in the track let it moved free.
SOURCE: error code H5-01
HI.H5-01
it shows there is some problem in exit sensor .it is in fuser unit.may be its lever is broken .
sensor is dirty clean it
check lever home position and its movemment
check its cable
reset this code
press ,p,*,clear,*
screen will go dead press 14 ,start code will bi reset
never forget to rate the solution.MIAN AKHLAQ
That is an easy one. That code means you had 5 jams at the POD1 sensor.
1) press #,*,C,*(enter simulation mode)
2) press 14, print, CA(clear all)
Should reset the copier to a normal state.
