Question about Car APS921 Remote Starter - Keyless Entry
Remote will only start when i am close to vehicle
What is stping the starter from starting car from a distance
  • 4,134 Answers
It depends on many things - mostly the range of the system itself and especially where you located the remote antenna. Some installers don't use the antenna and that will limit range severely. Most manufacturers want the antenna routed up the windshield pillar and mounted near the top of the windshield glass. This gives best reception since glass does not hinder the RF signal. OF course, a weak battery in the remote can cause range issues as well.
Posted on Nov 25, 2015
Testimonial: "there is an antenna on top of windshield and i replaced the battery..still the same"
SOURCE:
Why won't remote starter start vehicle from a distance?
sounds like you have a weak battery in your remote starter, you need to have checked out
Nov 25, 2015 | Cars & Trucks
Remote starter with antenna ford 150 1999
then contact the place you bought it . we do not have that information here
Mar 02, 2015 | Ford Vehicle Parts & Accessories
But my remote starter cannot open the door or closed
You really need to be more specific if you expect some assistance with your problem. What's the make and model of your remote starter? What's the year, make and model of your vehicle?
Jan 10, 2014 | Remote Start System
Last Year I installed an AVITAL5103 Remote start & Security on My 2002 DODGE RAM 1500 Q.Cab.Everything was working fine,util I instal a new car battery.When I attempt to remote stert ,the starter cra
There are two types of starters for Dodge, if you installed new battery, check to see if the remote start is to ignition module or starter solenoid, then make sure the circuit has not been closed-they go in series circuit!
Nov 29, 2011 | 5103L Security/Remote Start System
How do i use the auto start
To operate the remote starter, press and release the green trunk/key button on the remote twice within two seconds like so: press (thousand one), release. press(thousand two), release. Wait. If you press the button too fast the unit will only read it as one, especially at greater distances and, you may actually start the car and shut it down before it even starts.
Jul 24, 2011 | Car APS997A Two-Way Remote Start and...
I have 1999 Toyota Highlander with Pursuit Series Model 08SPr remote starter in it. I left the lights on battery ran out. I started car with jump. After that everything works except the remote start. I...
Check the hood pin switch. It's located under the hood around the edge of the engine compartment. It's designed to make contact with the hood when the hood is closed. Also, check for a remote start shutdown toggle switch under the dash.
Jul 20, 2011 | Car APS921 Remote Starter - Keyless Entry
I have a prestage remote starter, my car is 2008 ford explorer, after a few days my car will not start, it makes a clicking sound
The vehicles makes a clicking sound when using the remote starter? Does the vehicle make the same sound when attempting to start with key? If so, this sounds like an issue with the vehicle not having enough power to start the car or, there is an issue with the vehicles starter.
Mar 22, 2011 | Prestige Remote Start
Cars rpms goes extremely high, have to shut off engine unhook battery to reset computer, remote start, then works ok for a while. I noticed the problem more often if temps out side are extremely cold. ...
The problem you have described do not sound remote start related. A remote start unit does not have the ability to alter the RPM. The remote start system only replicates the process of turning on the ignition, starting the engine and keeping it running for a predetermined length of time.
The heater temperature problem should not be remote starter related either.
As for the day time running lights, although rare, if wired inproperly there is the possibility that the remote starter has caused it to fail. This will have to be determined by a qualified technician.
Jan 23, 2011 | Remote Start System
What to do if remote does not start the truck?
If the remote starter it was working before, check that all the doors trunk and hood are closed. And remote start the vehicle, approach to the window to see if the dash board lights turn it on if it does; check the pin switch make sure when you close the hood the switch get closed too if this is Ok. Check the tack wire you?ll see it is coming out of one of the ignition coils.
Jan 06, 2010 | Omega MARS-22 Remote Vehicle Starter with...
Car APS921 Remote Starter - Keyless Entry Logo
55 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Mike
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
