Kitchen Ranges Logo
T
Tj O Sullivan Posted on Nov 24, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i by pass the clock or timer to be able to use the main oven they are worked by electricty
Claude Kayser
Level 3:
Top Expert:
  • Kitchen Ranges Master 9,098 Answers
  • Posted on Nov 24, 2015
Claude Kayser
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5063157
Points
28436
Cooker dead or oven not working or clock flashing - YouTube
? 3:05
https://www.youtube.com/watch?v=FDz4UpFMXq0
Dec 20, 2011 - Uploaded by Richard Saupe
Can be quite a problem when your cooker or oven is dead and always ... want to use it. watch this video on tips to re set theclock and get it up and ru. ... I try to set time I'm after a video clip on how to change the timer any help .
My Rangemaster 110 oven will not light, the timer/clock is ...
www.howtomendit.com > Kitchen Appliances, Gas Cookers
Free repair help - rangemaster 110 oven will not light timerclock broken too. ... I turned off mains electric then took out the 5 screws .... all I was interested in was bypassingthe timer and not fixing the timer -like others ..... Like I say, you will have no clockfunction but will be able to use the oven in the way it was meant to work.
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
1helpful
The digital clock on my beko dv555 cooker isnt comin on and as my cooker was on timer now my main oven doesnt work either but my grill and hobs do
Try turning off the power for 3 minutes to try and reset the clock module. If this does not work it will need the clock replaced or a clock by pass done. A good electrician can do this.
Mar 09, 2011 • Ovens
Timer dosn't work therefor oven dosn't go on
The timer must be working and must be in manual mode for the oven to operate. If the timer is blank it is probably faulty and you will need a new timer. If you don't need the timer/clock the timer can be by-passed inside the oven by someone who knows what their doing and the oven will work no problems.
Mar 01, 2011 • Ovens
We were given an electric smooth top kenmore range. When it was initially plugged in, the digital panel came on. When the stove was pushed into place, the digital clock/timer went off and the oven won't...
The electronic timer/clock must be working and be in manual mode for the oven to work. Try turning the power off and on and see if it resets. If is doesn't you might need a new timer unit. If you don't need the timer and clock it can be easily by-passed at the rear by joining the active and load wires and the oven will work.
Range Model YKESC307HWO: Received Voltage Spike from Power Supply Company resulting in damage to several appliances including my Kitchen Aid Range. The control panel does not light up anymore, resulting in...
It sounds like the control board of the timer is faulty. Do you need the electronic timer/clock. If you don't it is normally easy to by-pass the timer altogether. Find the main active wire coming into the timer. Then identify the load wiring which runs from the timer to the oven thermostat control. These two wires simply need to be connected and the timer is bypassed and the oven will work.
6helpful
2answers
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
We have Smeg DUCO8CSS double electric oven. Bottom oven does not work, clock is blank and fan doesn't work. Top oven OK ! - though usually the fan runs when this is operating.
If the clock is blank, then the main oven will not work, as the clock timer is linked with the main oven.
You need to to get the clock working, or you will not be able to use the main oven
Jenn Air Oven Repair
HI thanks for the question. you can by pass the clock so the oven will work without the timer. call a tech near you, and ask them to by pass the timer. if i could get the wiring diagram, i could tell you how . its a simple thing to do. thanks the appliance doc. please rate my answer.thanks
FAULTY TIMER/CLOCK
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Top Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
