Kitchen Ranges Logo
K
Kathryn Kearney Posted on Nov 24, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error Code F05. Was attempting to set oven to clean.
David Smith
Level 2:
Scholar:
  • Expert 120 Answers
  • Posted on Nov 25, 2015
David Smith
Expert
Level 2:
Scholar:
Answers
120
Questions
Helped
20259
Points
316
Depends on the brand and model. seeing how you were attempting to clean it, could be a lock, thermostat or control board issue.
1helpful
How do I fix the error code F05 0n my Zanussi oven
try leaveing off at main cooker switch over nite
Error code f05 hotpoint ultima
In your service manual it states F05 - Pressure switch jammed on full many times I find this is due to a blockage in the drain line and if you take and clean out the drain line it usually alleviates the problem most of the time due to this error. I also find that while doing this it is best to also check the drain line that comes off the water opump as well as the one that goes from the bottom of the tub to the pump as well. Also checking the pumps impellar that it does spin freely assures future useage without problems for a much longer time with your washer. If you have any further questions message them back. Please also remember when our chat has fully concluded to rate how this opinion has helped in your appliance situation. By doing this it allows me to continue helping others in similar situations in the future.
Thank you
Rick
Its dispalying error code F05
Code F05
Description:
Water temperature sensor error. If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "F05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component.
Hope this helps (remember to rate and lave a testimonila about this free answer).
5helpful
Error code f05 flashing, what is this and how serious?
Error F05 means the pressure switch is jammed on full.
Remove the lower rear cover of washer.
Remove the large black hose fastened to bottom of drum.
Clean the plastic filter inside hose.
Remove the hose onto the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
3helpful
Coming up on screen F05
Error code F05 means pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Please leave feed back.
Thankyou.
8helpful
Fault code F05 on an indesit washing machine WIXE 167.it not emptying the water
Error code F05 means that the pressure switch is jammed on full.
Locate and remove large black fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Hop[e this helps you.
1helpful
Kenmore Elite Oven/Stove Fire Hazard?
F05 has to do with the self cleaning mechanism. I know it goes with out saying, but sparks and smoke are a bad thing. i would strongly suggest turning off the breaker and calling in a service person.
Smoke means extreme heat or FIRE is melting something..
Please be safe and have it fixed..
2answers
Error code F05 after the start of wash cycle
F05 is a water temp sensor error ,could be a bad heating element, or the temp sensor may be faulty, try checking the connection's to the temp sensor and heating element, also check the element relay.
2helpful
2answers
ERROR CODE F05, FOR KENMORE ELITE HE3 WASHER MOD.110.43862400
Click on the following link for diagnoses and troubleshooting tips for the "F05" Error code.
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
If you have questions and/or require further assistance, please post back and let me know. I hope this helps you.
2helpful
Electric oven model 790.47892601
F7-E1 - Common Switch Wire Is Defective - This error occurs when common wire to latch switch and door switch is shorted.
Check all connections at control board and at the latch switch and door switch.
If connections are ok, then check individual switches as outlined for the F5 error code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Top Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
