Question about Panasonic KX-TA824PK Phone
I put two out side line in my phone and only one work
Why no dialing tone
no dialing tone indicates an open line or an extension that has not been hung up properly. IF you have a corded phone then it may be in the cord (broken at the hand piece or at the base) On the technical side it may be from the wires in are not paired properly ( go google and check for phone line pairing) and on the financial side the account has not been paid
Jul 06, 2014 | British Telecom BT BIG Button Corded Phone
Panasonic phone says check tel line
Check cable conections from phone box on wall to base unit, make sure that the conectors are fully inserted. If possible plug a different phone into box to make sure that line is working. Hope this helps
Jun 08, 2017 | Lands Phones
Would you please be able to tell me how to programme a number in this phone.... on a specific button down the side.
What happens when you dial "9" on the intercom? If you get an outside line, then your phone is programmed properly. If you get an empty line, then you need to disable vacant lines in system program 400.
To program the right side buttons for speed dial, press PROGRAM a button on the right side, and dial 9+ the number as you would dial it on an outside line, then STORE.
On the left side, a waste if you're putting speed dial number sin, you dial 29 instead of 9, but normally you reserve them for lines, extensions, and features that require lit buttons. The codes would begin with 0,1 and whatever the magic code for the features are.
Carl
May 05, 2011 | Panasonic KX-T7730 Corded Phone
It ks660 LG phone the touch screen not working. very very slow this came about 2 weeks ago, I did reset and no resolution to the problem
the solution to this problem is this - pull down(put pressure) the silver line between the screen and key pad, you will notice that the screen will start responding. So what i did was that i removed my screen protector(foil), fold it into two then push it down on the right side then cut it with a sharp razor blade.
the whole idea is just to put pressure between the silver line and the screen region.
Try it!
REGARDS
Godfrey Ekele (Port Harcourt Nigeria)
May 06, 2010 | LG KS660 Cell Phone
Can't see diplay only see alines and light
do one thing ...put the battary in side phone then press on off butten then after three minut press down side on the phone reset butten press it after three minut remove battary ....then check
Dec 28, 2009 | O2 Xda Orbit Smartphone
The directional pad on my phone wont work when i slide it up. and i can't hear anyone when i call them although they can hear me. i can hear them if i put them on speakerphone, though
I don't have a solution.. Sorry.
But last night I couldn't hear the voice on the other line, but they could hear me. And now, not the up, down, side to side buttons; but the menu and options button only work when my phone isn't up.
Nov 14, 2009 | Samsung Propel Cell Phone
Iphone screen white, clicks and turns on and off but cant see!
if is not water damage , apple should repair it. If not well open the iphone go to youtube see vid how to open it. turn off iphone open it just pull off #1 and put back in. that's the lcd connector. This should work if not take #1 then #2 and # 3 put all conector back that should work. #1 Lcd conectot #2 is the Digitizer #IS the ligth. If you got gray lines the lcd may be broken.
Apr 04, 2009 | Apple iPhone 3G
Having phone line error
Disconnect the phone line and put a phone on it. If it doesn't work on the phone, go to where the phone line goes into the house and see if the phone works there. If it does not work there call the phone company and tell them you phone line doesn't work.
Jan 28, 2009 | Lexmark X5470 All-In-One InkJet Printer
KX-TG6700 Freeze
Remove the base by taking out the five screws. Look for the ribbon cable on the left hand side. On each side of the cable is a little brown nub, pull away from the circuit board to release the tension. Pull the ribbon cable out, this will reset the circuit board. Put the ribbon cable back in and push the nubs towards the circuit board. This will add tension to the connection. Put the base back together using the 5 screws. Plug in your phone and you should be set.
Austin Ron
Jun 07, 2008 | Panasonic KX-TG6700 Cordless Phone
Fax line stays busy continously...
Still a problem? Can you be more specific?
Jan 29, 2007 | Canon FAXPHONE L80 Laser
Panasonic KX-TA824PK Phone Logo
54 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
