Worked fine 'til today.
SOURCE: Phillips GoGear SA5125/37 wont power up
The freezing at 87% suggests hardware malfunction, but you can try all of the "soft" fixes to be sure -
Triple Reset for GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player.
Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
SOURCE: My Sony WALKMAN mp3 player won't charge
If it is a NW-A1000 I have a copy of the service manual please download it from HERE from deposit files..will be active until 29th November 2009, let me know if you need it for longer.
Goto page 9 section 4 TEST MODE.
1. Press HOLD to put the player in hold mode.
2. Hold down LINK and press in order UP, DOWN, OPTION, UP, DOWN, RIGHT, LEFT, RIGHT, LEFT, LEFT, PLAY/PAUSE, OPTION.
3. Press HOLD to turn hold off. You will now be in test mode.
4. Press RIGHT to display menu items
5. Press the UP,DOWN to select the POWER
6. Press RIGHT to select V CHK
7. Press the PLAY key START is displayed and all the power lines will be started.
TP9027: 1.10 ± 0.05 V T
P9023: 1.3 ± 0.1 V
TP9026: 1.8 ± 0.1 V
TP9031: 3.0 ± 0.1 V
TP9018: 3.0 ± 0.1 V
TP9028: 3.3 ± 0.1 VT
P9024: 5.0 ± 0.2 V
You can check these on the main board to see it all are present if one is missing this will be why your walkman wont hold any charge.
LOL
SOURCE: my gigaware mp3 has a full battery charge but wont work
Slide the unlock bar on the side of the mp3 player. It is on the left side of the player.
SOURCE: charging problems
Your player's internal battery hs died. You will need to obtain a replacement. Check your user manual for size & type, or check it out on the web. Sellers from China offer large range of replacements.
SOURCE: Archos 18 vision 8gb. Battery will not charge.
According to you your MP3 player is not working for battery. Make sure the charger is OK and working fine. You can change or replace the battery. Your battery circuit unit may be faulty. You can try to charge it in turn off mode of the player. If it is new unit then the player is in warranty. Then you can go to the nearest service center or your retailer for repairing or replace.
