Panasonic KX-TG5632 Phone Logo
Posted on Nov 24, 2015
One of my phone screen is lit and there is some text, but line that should show phone number is all downward arrows
Change the font style on a Bee3 label maker
1. Press "Style." The screen shows "lines." Press "Return." 2. Use arrow key to select "1 Line" (or "2 lines" of text, etc.). Press "Return." 3. Use arrow key to select "1a," "1b", "1c," or "1d" (text). Press "Return." 4. The screen says "vertical." Arrow down to "END?" Press "Return." Then the screen shows "AREA Label." Press "Return." 5. Type your text. Preview and Print. Call 1-800-622-6312 fmi or a manual! Changing the font on your Sun BEE3 BEE3 label printers
3helpful
I have a Bee3 label maker and I need to know how to change the font size.
1. Press "Style." Thescreen shows "lines." Press"Return." 2. Use arrow key toselect "1 Line" (or "2 lines" of text, etc.). Press "Return." 3. Use arrow key to select"1a," "1b", "1c," or "1d" (text). Press "Return." 4. The screensays "vertical." Arrow down to "END?" Press "Return." Then the screen shows "AREALabel." Press "Return." 5. Type your text. Preview and Print. Call 1-800-622-6312for a reference manual. We can answer any other questions you might have too!
1helpful
2answers
Hi there ... We have 4 lines in the office but on one of our M2000 series Meridian phones only the first 2 line buttons receive a dial tone ... How do add lines 3 and 4 to the next 2 buttons?
Programming is done on M7310, M7324 and T7316 sets.
To set up line appearence you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program the new lines on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the next key (bottom right arrow) till it says 003:unaaign.
press the chng key till the screen says appear&ring
Press the next key(bottom right arrow)
The display should say line 004: unassign
press the chng key til the screen says appear&ring
press the Rls key when finished
I NEED TO SET UP 4 PHONES TO HAVE A LINE 5 AND A LINE 6. THE BUTTONS FOR THE EXTRA LINES ARE PROGRAM WITH SOMETHING ELSE. HOW DO I PROGRAM THE PHONES TO HAVE LINE 5 AND 6.
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
press the next key (bottom right arrow) till it says 025(or 031):unaaign press the chng key till the screen says appear&ring
The display should say line 026(or 032): unassign
repeat the procedure the same as line 5 for line 6
press the release key when finished
7helpful
Phone will not ring
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)
The display should say line 002: appear only
repeat the procedure the same as line 001 for the remaining ringing lines
2answers
Phone doesn't ring
Programming2_bing.gif is done on M7310, M7324 and T7316 sets.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
4helpful
How do you get a t7316e phone to ring
1helpful
How do you program so that when the phone rings you are able to pick up the call without hitting a button. Also when you make an outgoing call and you pick up the phone you get an active line instead of...
Sets that are programmed to ring should automatically have ringing line preference.
The 4 top line/feature keys are now used for programming2.gif.
press next key (lower right arrow)The display should say line 002: appear only
repeat procedure for remailing active lines
press the heading key (top left arrow) til the screen says terminals&sets again
Prime line assignment is also programmed at the terminals&sets prompt.
press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the prime line on.
The display should say Line Access
The display should say Line Assignment
Press the next key (bottom right arrow) .
The display should say Line Pool Access.
Press the next key (top right arrow)
The display should say Prime Line
Press the Chng soft key till you get to the desired line or pool to pick up on
Press the release key when finished
1helpful
Only certain lines ring on certain phones
Programming2.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The display should say line 001: appear& ring2.gif
press next key (lower right arrow)til you see the line port number you wish to program (004)
The display should say line 0xx: appear only
1helpful
I want only the receptionist phone to ring
To change ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The display should sat line 001: appear and ring press CHNG til it says appear only.
Repeat same procedure as line 001 til all available lines are done
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
