Precor 9.27 Treadmill with Ground Effects Technology Logo
thushara nuwan Posted on Nov 24, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
R5,R11,ZD2,R12,value - Precor 9.27 Treadmill with Ground Effects Technology
richie46
Level 3:
Top Expert:
  • Master 12,962 Answers
  • Posted on Nov 24, 2015
richie46
Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2943132
Points
58151
Did you try contacting the manufacturer? The resistors are color coded and no problem to replace but the zener diode is another matter. Take it down to a repair shop and perhaps they can identify it from the markings and/or size.
2helpful
2answers
I have a B&D Firestorm 18v 1-hour battery charger, model 5100235-09 (240v). When I insert a battery to charge, only the green "battery full" LED lights immediately. But the battery never...
Hi I have same problem with the charger. Solution is to replace the charge with new part number issued from B&D Australia
Number of 90515050-01 until stock runs out , then it is replaced by part number of 90578873 early to mid june 2013.
Hope this helps
Lance from Perth , Western Australia.
2helpful
MY FORD TAURUS 1996 IS RUNING AND SUDENLY STOP AND IS DEAD, WHY.
tv1709~us~en~file=adobe.gif~gen~ref.gif Printable View (11 KB) Article No.
97-17-9
  • STALL - ON DECELERATION AND/OR INTERMITTENT STALL IN WARM WEATHER - VEHICLES BUILT THROUGH 8/18/96 AND SHO BUILT THROUGH 8/6/96
Publication Date: AUGUST 18, 1997
FORD: 1996 TAURUS SHO, TAURUS LINCOLN-MERCURY: 1996 SABLE This TSB article is being republished in its entirety to correct a service part number. CALIBRATION: 6-10A-R07, 6-10A-R10, 6-10A-R11, 6-10A-R12, 6-10S-R07, 6-10S-R10, 6-10S-R11, 6-10S-R12, 6-10B-R06, 6-10B-R10, 6-10B-R11, 6-10B-R12, 6-10T-R06, 6-10T-R10, 6-10T-R11, 6-10T-R12, 6-14A-R07, 6-14A-R08, 6-14A-R10, 6-14A-R11, 6-14S-R07, 6-14S-R08, 6-14S-R10, 6-14S-R11, 6LDA-JAD tv1709~us~en~file=caution.gif~gen~ref.gif WARNING: THIS MODIFICATION IS AUTHORIZED ONLY FOR THE LISTED ENGINE. PERFORMING THIS MODIFICATION ON OTHER ENGINE CALIBRATIONS IS UNAUTHORIZED AND COULD CREATE LIABILITY UNDER APPLICABLE FEDERAL OR LOCAL LAWS. ISSUE: Some vehicles may stall on deceleration and/or have an intermittent stall in warm weather. This may be caused by the vapor control valve not supplying a steady flow of fuel from the tank to the intake manifold.
ACTION: Replace the fuel tank, vapor control valve, fuel fill tube cap and clamp. Install heat shield over fuel tank and reprogram the Powertrain Control Module (PCM). This should reduce the possibility of stalling. Refer to the following text for details.
Perform all diagnostics for stalling by following the procedures outlined in the 1996 Powertrain Control/Emissions Diagnosis (PC/ED) Service Manual and 1996 Taurus/Sable Service Manual, Pages 03-13-5 through 03-13-8. Check to be sure Grounds 401 (sedans) and 400 (wagons) are secure. Check for a kink in the canister vent hose and repair as required. If no other concerns are found, reprogram the PCM using the latest level CD-ROM update disc and refer to the following PCM Application Chart for correct PCM usage. Replace the fuel tank, vapor control valve, and vapor management valve by following the procedure outlined in the Instruction Sheet included in the Fuel System Service Kit.
PCM APPLICATION Old Calibration Old Part Number (-12A650-) New Calibration New Part Number (-12A650-) 6-10A-R07,R10, R11, R12 F6DF-BF 6-10A-R12 F6PF-CVB 6-10S-R07,R10, R11, R12 F6DF-DF 6-10S-R12 F6PF-CYB 6-10B-R06,R10, R11, R12 F6DF-JD 6-10B-R12 F6PF-CXA 6-10T-R06,R10, R11, R12 F6DF-KD 6-10T-R12 F6PF-CZA 6-14A-R07,R08, R10, R11 F6DF-EG 6-14A-R11 F6PF-CGA 6-14S-R07,R08, R10, R11 F6DF-FG 6-14A-R11 F6PF-CFB 6LDA-JAD F6DF-RD 6LDA-JAD F6PF-CDA
Refrigerant gas used in Kenmore freezer
Hi: You didn't give me the complete model number. Not to worry though. Look at the model number tag of the freezer. If it's a newer model it will use R134A coolant. The tag will tell you the amount of refrigerant and the type. I hope this helps, Jeff.
1996 Ford Crown Victoria Shifting
when was the last time you had the fluid and filter changed? This trans should be done every 30,000. Is it shuddering as the torque converter locks up?
TSB 97-10-6 has a repair procedure for this ysmptom:
Vehicles equipped with an AODE or 4R70W transmission may experience a torque converter clutch shudder or vibration. This occurs under light to moderate acceleration above 56 km/h (35 mph) while in 3rd or 4th gear. This may be due to either transmission fluid breakdown and/or the Powertrain Control Module (PCM) calibration.
Verify that bulk fluid does not have moisture contamination. If suspected, use quart containers of MERCON®. Refill transmission with the proper amount of Motorcraft MERCON® Multi-Purpose Automatic Transmission Fluid (ATF) (XT-2-QDX).
NOTE: DO NOT USE MERCON® V.
Check emissions decal to verify vehicle has the latest calibration. If it does not, reprogram the PCM to new calibration level using Service Bay Diagnostic System (SBDS) or New Generation Star (NGS) Tester with May 1997 CD-ROM or later. Refer to the PCM Calibration Chart found at the end of this article for proper application.
NOTE: VEHICLES SHOULD BE DRIVEN A MINIMUM OF 480 km (300 MILES) TO WORK THE NEW FLUID INTO FRICTION MATERIAL.
PCM CALIBRATION CHART Application Old Calibration Old Part Number (-12A650-) New Calibration New Part Number (-12A650-) 1996 Crown Victoria/Grand Marquis 49S/Canada/High Altitude 6-18F-R05/R11 F6AF-AE 6-18F-R11 F6PZ-DJA 49S/Canada/High Altitude 6-18H-R05/R11 F6AF-BE 6-18H-R11 F6PZ-DKA Mexico 6-18H-R05/R11 F6AF-KE 6-18H-R11 F6PZ-DMA Police 6-18I-R05/R12 F6AF-CF 6-18I-R12 F6PZ-DLA California 6-18M-R05/R11 F6AF-DE 6-18M-R11 F6PZ-DNA California 6-18N-R05/R11 F6AF-EE 6-18N-R11 F6PZ-DPA
2answers
Maytag Neptune MAH4000AWW
if r 11 is bad you should really check the bearing on the tub you will probably find it to be bad or going bad causing the moter to pull more amps causing r 11 to burn out.
Door won't lock. R11 on Household Machine Control board is blown. WOuld like to know the value of R11 for component replacement.
don't waste your time been there done that other componets are damaged ..you need a new control bd and door latch wax motor
Maytag Neptune m/n MAH3000AWW burnt R11 resistor
STOP
There is a short in the door lock (very, very common problem )
Go to ebay and search neptune washers and im sure youll find a site i was selling a kit to repair this. If you cant find it let me know ill look .
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
