We have cleaned all filters and vents to outside....ran several loads and then problem started again
Dryer Thermal Fuse Replacement - LG Electric ... - YouTube
? 5:29
https://www.youtube.com/watch?v=b74Mt5sSgRI
Dec 21, 2012 - Uploaded by RepairClinic.com
Dryer Thermal Fuse Replacement - LG Electric Dryer Repair (Part ... The most common reasons for replacing the thermal fuse are when the dryer won't start or ... I have an LG GAS DRYER model # DLGX8001V and it will not ... My front load dryer won'tturn on. .... My LG dryer recently stopped working.Missing: seconds
LG Electric Dryers, no heat? Try this first... - Home Forums
ths.gardenweb.com > Home Forums > Laundry Room
Apr 1, 2006 - I own an LG Electric Dryer model DLE0332W. ... Serviceman: The part you need is a heat regulator and its going to run you about $20 and the labor ... Look into the hole to the left and you will see the Heater Unit right within reach. .... Came back a second time because it still wouldn't dry my clothes (maybe ..
Testimonial: "I understood the fuse could be an issue when it won't run at all....it gets hot and runs for 20+/- seconds before stopping -- all lights are still on and displaying that it is drying. Can this still be the fuses?"
Is there any fault code mark?
No, I am not getting any error codes. If it sits a minute or so, it will start again, run 20 seconds and quit.
I was wondering if the door switch could be the problem...I read something about that. But I have not found my exact problem listed anywhere
There is a door latch and a latch sensor that may cause the problem
