It's just started happening so I changed the cartridge but hasn't helped. It uses too much ink and time to print on normal
SOURCE: Lexmark Z517 wont print black ink
I have a z600 that i use. If not used for about a month the ink does clog the print nozzles and eventually ink cartridge does dry out. To avoid this even if i dont have to print anything I run a diagnostics test that prints out a nozzle aligment test every two weeks.The great thing about this is that it uses very little ink.You can find this test in your software that was provided by Lexmark. This will keep your nozzles cleaned and you will notice this helps extend the life of your cartridge.
SOURCE: White lines appearing on print
White Lines on the Printed Page
Clean the print nozzles as follows:
For additional help, refer to the following article: How to Clean the Maintenance Station .
SOURCE: My printing displays wrong ink levels and prints blank pages
If your cartridge is new (or full) and you know that not just from ink levels display, then you did not used the printer for a while (at least a month) and the nozzles of the cartridge are clogged. If u used the cartridghe 4 or 5 moths ago, then the whole cartridge is dryed out, so get out and get yourself a new cartridge.
If it's just a month, then you should put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the cartridge with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridge in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the cartridge on some sheets of tissue.
Install the cartridges it in the printer and run a few cleaning processes from the printers maintenance software.
If the cartridge is new and just installed in the printer, and you have the inklevels but it does not print, then get it out of the printer and back to the store, they should replace it for you. I hope you removed the protective plastic stripe that covers the nozzles before installing the cartridge?...
OK, let ne know please how things evolve.
Hope it helped you, rate the solution.
Almoust forgot: ink levels are displayed by Lexmark inkprinters by estimating the ink consumed trough you printing process, it has no sensors in the cartridge. It's just kind of a counter, you can evan set an empty cartridge to be seen as a full one.
SOURCE: Printer doesn't print even with new ink cartridges.
Take out the Cartridge & get a new one if the problem persists then get the printer software reinstalled & if still it is not printing then clean up the cartridge head with cotton swabs dipped in hot water!
This should clean the head & black will be on paper
DO THIS AS FINAL REFUGE
If still its not working then there's some problem in the copper contact surface in the printer on the cradle so get a new Printer.
SOURCE: Lexmark X 5150 prints blank pages
Hi !!
Try this ---
take out the ink cartridges from printer
Take a tissue paper and make it damp with water
Then CLean the bottom part of cartridge where you see some golden contacts , just wipe it off with damp tissue .
Check if there is any ink coming on the tissue or not .
If No ink coming out , may be u forgot to pull out the protective tape or there is no ink inside the cartridge
Let me know what happens
Priya
