SOURCE: Extention Display Name
This detailed instruction is not in the small book that came with the phone. It will be found in the binder or full sized publication titled “User Manuel’ for the models KX-TD816 and KX-TD1232 that came with the phone system.
You will want to use the overlay that DID come in the smaller book. You will place it on top of the buttons and it will provide programming commands listed in the instructions.
Page 71 has the “Getting into programming” details.
[Program], **, 1234
Now you are in user programming mode.
Page 87 will instruct you how to program names.
Press 004, [Next], [jack number] (ext 101 = jack #01-1, ext 102 = jack #02-1 ect…)
Once the jack and the old name are displayed, press [Clear] and then start pressing the letters according to the “Overlay”. (3 = 3 D E F) press the S-button that displays the correct character. S-buttons are the 3 buttons directly below the display. When you are done press [Store] and you can press [Next] to se more jacks or just exit by pressing [Program].
SOURCE: Changing Names on Extention Numbers from Main Phone
program,**,004,enter,(type in name using number keypad)enter, end.
SOURCE: Extention Names?
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system -
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( default is 1234).
2. Now press 004 and then ENTER.
3. Enter the extension number you want to change.
4. Enter the name (the same way as texting on a cellphone.)
5. To save the changes press AUTO DIAL / STORE.
6. To go to the next extension press NEXT on the screen.
7. Lift the handset and put it down to exit program mode.
