The clothes are not wringing out. I bought this used, it runs fine, other than the clothes not wringing out. I have ran a vinigar wash through and cleaned out the lines, thus far.
www.diychatroom.com/.../washing-machine-wont-wring-out-clothes-pro... Apr 16, 2013 - 6 posts - 4 authors
... thing - the spin cycle doesn't really seem to do an effective job of wringing out theclothes once. ... Sounds like it's not spinning fast enough.
If you can get to the drain hose and hold it low down, the water should come out allowing you to get to the clothes. Be careful where the water goes though.
Dear Barry, Try 2 things. One, be certain the clothes are very dry coming out of the washing machine. If the washer leaves the clothes wet ( like the belt might be slipping), it can take the dryer forever to finish drying the clothes. You can tell by hand-wringing them. You should not be able to get any water out of them by hand-wringing after they have spun dry in the washer. Two, try running a load with the vent hose unhooked off the back of the dryer. If this fixes the problem, you are having a "clogged vent" issue somehow. Be blessed.
Don't pause the cycle mid cycle. The machine uses the amount of water it needs to clean the amount of clothes that are in the tub. If you pause it after the first 7 or 8 minutes, you're already past the sensing part of the cycle and likely you won't get more water for the additional clothes.
Also, the clothes don't need to be soaking wet or wet enough to wring out. These new HE machines mix the detergent with water and then spray that detergent solution onto your clothes. Then the clothes against clothes rubbing with that solution already coating the clothes is how the machines clean better! It is a very similar process to when you pretreat your clothes with Shout of Spray and Wash. You spray the clothes and then rub the short against itself. Now the Whirlpool machines are doing this for you!
It sounds like you need a water pump!
See if it's pumping water next time you do load by looking at the discharge hose going to the drainage pipe and get back to me!
jack
