Losing ripped CD's And downloads from Windows Media Player
Using windows media player when I rip a CD it will only save until I close the WMP . When I reopen the WMP the music is gone . What is going on? How do I fix this. This just started . I have ripped and Downloaded many songs and they are still in the WMP. Please help!
Normal audio CD tracks should be converted to mp3 files onto the computer's hard drive, first.
This is called ripping or RIP function.
There are several programs that can RIP audio CD.
It is important to convert music into the correct bitrate for the player to match for playback. (192 kbps is good quality and often used)
You can use Windows Media Player 10 or 11 for conversion.
When you use WMP 10 or 11 and the player is detected in the program:
1. Tell the player were your music library is: setup your music library.
2. Create a playlist; make playlist name and add mp3 files to the list.
3. Synchronize the playlist with mp3 files to the player.
If the player cannot be detected in WMP 10 or 11, but only can be viewed as a removable disk in "My Computer" : use the "copy and paste" or "drag and drop" method to put mp3 files from the computer onto the player.
When needing more help, don't hesitate to write a comment in this reply.
Are you trying to synch tracks directly from a CD. If you are, you first have to rip the tracks. In windows Media player, you first need to setup the type of file you want to rip to (MP3 in this case). Right click on the top bar of the WMP and select Tools|Options. Select the Rip tab and under the rip settings, change the format to MP3. Select the quality you want (higher quality means less music can be stored on your unit). 192 kbps is a good setting. Now, click OK or apply as appropriate to get out of the menu. Insert your CD and click on the RIP tab of WMP. Your CD's tracks should automatically come up with checks marks beside them. Start the RIP process. Once it is complete, you can then drag the newly ripped files from your library to the Walkman and they should be synched.
go to this website download. and click on the download link if that wont work for you if all your trying to do is rip cd's to a collection then you can also use windows media player to do it, open up windows media player and click on the rip tab then insert your cd and when it comes up with all the names and information of the cd then click on the rip button at the bottem of the screen and in about 10-15 minutes your cd will be in your new windows music library and should be saved under my documents\my music from there you can put your new music on your mp3 player :) enjoy
Here's what you want to do. Use Windows Media Player to re-Rip the CD's in Mp3 format. Go to Windows Media Player 11 --> Rip --> Rip Options --> Format --> Mp3 (you can get to Rip options by moving the mouse over the Rip tab, and a small black arrow will appear - click on the arrow). Once the songs are in true mp3 format, you can then use the Sync tab in Windows Media Player to transfer the songs.
If Windows Explorer will not do the trick, then I would use Windows Media Player version 9 or 10 - I don't believe the older nextar's are compatible with WMP 11.
The instructions in these pages, which are largely links, pertain to Windows Media Player 10 and 11 only.
Windows Media Player is made by Microsoft. The general help page for Windows Media Player is:
Through
this link, you can enter a variety of search terms that will help you
find what you are looking for (exs.: “add files to my mp3 player”;
“delete files from my mp3 player,” etc.)
Important Vocabulary:
The code word for “mp3 player” in Windows Media Player is “DEVICE” or “portable device”
The code word for adding files is “SYNC,” “syncing,” or “synchronizing”
The code word for copying files from CD is “RIP,” or “ripping”
The code word for files stored on both My Computer and my Mp3 player (when it is connected to the computer) is “LIBRARY”
To add files (SYNC) to your mp3 player using Windows Media Player 10:
Connect your player to the USB port on your computer using the USB connector on
the Mix Max. A 'MIX-MAX' window will appear in your My Computer folder which is
the player's internal memory. To add more files and songs to your player simply
drag and drop MP3 or WMA files from anywhere on your computer into the 'MIX-MAX'
window.
For Windows XP, you can utilize Windows Media Player 10 software
to convert music on an audio CD into MP3 or WMA format as follows:
Open
the Windows Media Player 10 Browser, then click on the 'Rip' icon on the top
tool bar. Insert a Music CD into the CD-ROM drive of your computer. Click on
the 'Tools' menu option at the top menu bar, then click on 'Options'; the Option
setting menu will appear. Click on Rip Music and set the Rip music to the
desired location on the newly ripped music (MP3 format or Windows Media Audio
format). Adjust the audio quality as desired. When finished, click 'OK' to
confirm the settings. Click on the 'Rip Music' icon to start ripping the
music to your computer. When the music tracks are ripped; connect the player
to your computer. Open the 'MIX-MAX' window and open the ripped music location
window. To add the transferred/ripped music file/songs to your player simply
drag and drop the MP3 and/or WMA files into the 'MIX-MAX' window. When the
files are finished loading into the player, follow the 'Safely Remove Hardware'
procedure as shown below. Note: For Windows 98SE, Windows ME, and Windows
2000, please use the Windows Media Player 9 to convert music on an audio CD into
MP3 or WMA format.
Downloading WMA files with DRM using Windows Media
Player 10 (for Windows XP)
To download WMA files with DRM, follow the
procedure described below using the previously installed Windows Media Player
10. Before beginning the procedure please turn the unit on and connect the unit
to the computer as previously described.
Open the 'Windows Media Player
Browser 10' and click on 'Sync'. Click on the 'Sync List' pull-down menu to
locate the music files you wish to download. Then make sure to click the box
next to the files. Select the Portable Device that you want to copy to from
the right side drop-down menu. Click 'Start Sync' to start downloading the WMA
file(s) with DRM to the Portable Device. After finished downloading all the
desired files to your unit, follow the 'Safely Remove Hardware' procedure as
shown below. Note: For Windows 98SE, Windows ME, and Windows 2000, please
use the Windows Media Player 9 to download WMA files with DRM to your
player.
If you have Windows Media Player then,
Insert the CD into the drive
then In WMP click on the RIP tab and rip the songs from the CD
Then go to the SYNC tab and plug in the mp3 player and you should be able to transfer music from the computer to the mp3 player, any other questions, please post
Through
