3d Rose Londons Times Funny Music Cartoons - Ventriloquism University - Light Switc Logo
Posted on Jul 14, 2009
Stuck at finding server
Tried reinstall??and wont link to wowstead account
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Sep 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
21610
Points
6
You need to find out if you have a firewall or other piece of network hardware that could be interfering with your connecting to the server. One way to do this is to run the linux traceroute command or windows tracert like this:
> traceroute vent.ventserver.net
> tracert vent.ventserver.net
Also try pinging the remote host:
> ping vent.ventserver.net
Playstore wont let me,log in
The common solution to this problem is to go into your device settings, accounts section. Then, in airplane mode, remove google account. After account is removed, find your Manage Applications Section/All, find ALL stuff linked to your Google Account, i.e. calander, contacts, gmail, etc etc, and clear the data/cache (don't uninstall, just clear data/cache), then reboot, turn off airplane mode, reinstall your google account in system settings/accounts then try sync
There is also another issue I've encountered that has similar symptoms, but this solution does not fix that one. The issue it does NOT fix is the inability to connect to Google Play on Mobile Data. In this context the users are able to use Google Play via WiFi, just not on mobile data. (2 issues, this solution is for basic Google Play connectivity issues, haven't figured out solution 2 yet)
Jun 26, 2014 • Cell Phones
tip
4 Methods to Change MS SQL Server Password
Have you ever forgot or lost your MS SQL Server password? Did you reinstall MS SQL Server or change SQL Server Password by some ways at that time? I once forgot my MS SQL Server password and I reinstalled My MS SQL at last as I failed to find some good methods to solve the problem. What annoying and terrible experience it is! In order to avoid reinstalling SQL Server for a second time due to the same reason, so I collect some methods to change SQL Server password for sa account.
Method 1: Use Command Prompt to Change SQL Server Password
Step 1. Open a command prompt (Start -> Run -> cmd)
Step 2. Type the follow commands, and press Enter after each line:
Osql –S yourservername –E
1> EXEC sp_password NULL, ’yourpassword’, ’sa’
2> GO
The yourservername is the name of your server, yourpassword is the new sql sa password.
The command line 1> also can be changed to other command, the model is EXEC sp_password ‘oldpassword’, ‘newpassword’, ‘sqlaccount’.
Method 2: Use the Query Windows in Management Studio to Change MS SQL Server Password
Step 1. Open SQL Server Management Studio
Step 2. Open a new query
Step 3. Type the follow commands and excute:
GO
ALTER LOGIN [sa] WITH DEFAULT_DATABASE=[master]
GO
USE [master]
GO
ALTER LOGIN [sa] WITH PASSWORD=N'NewPassword' MUST_CHANGE
GO
The NewPassword is set for your SQL Server sa account.
Method 3: Change SQLServer Password by Windows Authentication
If Builtin/Administrator is present in SQL Server, you can login with an ID which is member of Administrators group and change sa password in SQL Server. Just do as follows:
1. Login into SQL server using Windows Authentication.
2. In Object Explorer, open Security folder, open Logins folder. Right Click on sa account and go to Properties.
3. Type a new SQL sa password, and confirm it. Click OK to finish.
After restarting SQL Server and all its servers, you can log into SQL Server by sa login with new SQL sa password.
Method 4: Change MS SQL Server Password with Third Party Software
In addition to the methods above, you can aslo choose some SQL Server password recovery tool to change SQL Server password. MS SQL Server Password Unlocker is one of the good MS SQL passwrod reset tools which can help you change SQL Server password in a few seconds. It allows you to chage MS SQL password on SQL Server and Express 2000/2005/2008.
Following is a guide for you to change MS SQL password with MS SQL Server Password Unlocker.
Step 1.Download and install MS SQL Server Password Unlocker.
Step 2. Run MS SQL Server Password Unlocker, click Open, import your master.mdf file. All the user names of your MS SQL Server will be displayed.
Step 3. 3. Select an SQL account, click Change password button.
Step 4. Type a new password, and then click OK.
This SQL account password has been reset. You can login with it.
Well, the four solutions are the easy-to-use MS SQL Server Password Reset ways.
on Aug 10, 2010 • Computers & Internet
Dell computer Windows 7 MSN for email Cannot send emails; they are stuck in Outbox
HI
GO FOR ACCOUNT SETTINGS CLICK ON YOUR ACCOUNT
AND IF IT IS GMAIL
INCOMING SERVER MAIL : POP.GMAIL.COM
OUTGOING SERVER MAIL : SMTP.GMAIL.COM
GIVE OK AND TRY TO SEND ONCE AGAIN.
DEFENETELY IT WILL GO
My garena gets stuck on the looking for ip address followed by "connection to server failed". i've tried reinstalling garena but to no avail
Try connecting to other servers. Garena has 5 servers. You can choose the server you can logon by pulling down the drop down list for Servers.
Hope this helps.
3helpful
Cannot find roku.com/link need to put in code to activate.
Open a web Browser
Go to www.roku.com/link
If new user create account else login to your account
Once logged in you will find Link player, click on it and enter the code
Else
For XP computer Click on start-->RUN-->http://www.roku.com/link
For Vista computer Click on start-->Start search-->http://www.roku.com/link
Print jobs wont leave spooler when using d-link 1260 print server. But do when connecting via USB.
This sounds like a defective driver problem with the print server. reinstall the driver. If this does not solve the problem then contact D-Link support for further advice.
1helpful
2answers
Incoming and outgoing servers
Well this totally depend upon email server that you are using. Generally it is pop server. For ports and server address you need to check this with the email service provider!!
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Linux drivers for Dell Poweredge 2650
try a search for Linux OR try www.downloads.com.. you will need to set up an account but the account is FREE and no recurring charges You might even try www.redhat.com that is Linux site and should be able to find your version there if it exists.. try the PLATFORMS link
2answers
Error #0x800CCC0D can't contact pop-server-hawaii.rr.com
search for proper mail server adderss on the net. then try creating account.
Top 3d Rose Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a 3d Rose Electrical Supply Expert? Answer questions, earn points and help others
