depends onn make and model of vacuum. Most brushes are belt driven and not linked to a motor. For hair around the brush bristles carefully cut along the length of the brush roller taking care not to cut any of the bristles, then pull them off. Some makes have a releasable base to make this easier, these have several large plastic screws that turn with a coin. Hope this helps
A common problem is for hair to get wrapped around and forced into the end bearings which causes the motor to work harder or drive belt to slip. Cleaning the hair out can be a short term fix but new bearings might be needed. It's also a good idea to replace the drive belt at the same time as the slipping belt is probably not going to perform well even with new bearings.
Make model? Maybe jammed make sure no hair is wrapped around the brushes by removing them (look up your model online I'm almost sure there is a how to video on YouTube) and clean it of all tightly twisted hair usually found where the brushes don't exist but on outer edges where you can't see between the plastic side of the vacuum and the brush roller (looks like rolling pin) where the bolt is that the brush spins on...hope that helps
You may need new belts. Belts lose elasticity from being stretched. The clutch must be removed and disassembled to change the belts. It's easier to replace the clutch. The belts will be tight and It's difficult without a special tool. While you have the brushroll out pull the shaft out of the center and clean hair and debris from it or replace brushroll if worn or frayed.
If it is a smell of burning rubber - most likely your vacuum belt is overdue for replacement.
At this point - remove the brush roller, remove the old belt, clean off your brush roller and remove any string or hair that may be bound up around it (usually around where the belt goes or on the sides), and put on a new belt. Your Kirby should act good as new if your bag is replaced at the same time.
If the brush roller has too much string and hair wrapped around it, many times the brush roller will not spin as fast as the belt is driving it and you will get that burning smell.
I had the same problem with my DC15. With the brushes going it smelled like burning hair (bad). I had cleaned the brushes many times and it didn't seem to help. I even took it into a Dyson authorized repair shop and they couldn't find anything wrong with it. As a last resort I called Dyson 866-693-9766 1-866-My-Dyson. I was on hold for about 15 minutes before getting a live person. He had my problem diagnosed in literally 1 minute. I had hair wrapped around the spindle, inside the brush/roller mechanism. He walked me through taking apart the brush mechanism (super simple only using a quarter). There was a TON of hair crammed around the spindles and inside the brushes. All wrapped very tightly. I hung up with him to do the cleaning. It took some time and I had to use tweezers to get inside the rollers/brushes. But I got it all, put it back together (which was really easy) and tested it out. No burning hair smell at all. FIXED!
It could well be the dog hair. You'll need to remove the roller brush and completely clean it off with the hair which sounds like it has wrapped itself around the brush and the brush end washers. Check that the entire roller brush is completely clear and if any dirt is found at the sides, remove it.
