Vantage 300 welder stopped working unexpectedly, oil presure, generator and coolant are ok. why is not starting again?
In the beginning after the welder machine started running shortly and then die. I already replaced the oil filter and checked the alternator and the fuel flow. Now it's worst it cranks but it is not starting.
There could be a few different reasons why the welder on the Miller Trailblazer 250G 4000 watt generator welder would quit working but the generator still works. Here are a few things to check:
Check the welding settings, make sure they are appropriate for the type of welding you are doing. Make sure the voltage and amperage are set correctly.
Check the ground connection, make sure it's clean and tight. The ground connection must be secure for stable welding.
Inspect the welding cables and make sure they are in good condition and that the connections are tight.
Check the welding gun and make sure it's clean and in good condition.
Check the main contactor and make sure it's engaging and disconnecting properly.
Check the main circuit breaker and make sure it's not tripped.
Check the power output of the generator and make sure it's within the correct range.
Check the control circuit and make sure that it's not damaged or malfunctioning.
Check the engine oil level and make sure it's not too low, low oil level can cause the engine to overheat and stop working.
Check the air filter and make sure it's not clogged, if the air filter is dirty, it will cause the engine to run hot.
It's important to check the manual of the welder for troubleshoot steps and also check the warranty of the welder and see if it's still covered by the manufacturer. If you are not able to find the problem or if you are not familiar with welding equipment, it's best to take your welder to a qualified Miller Electric welder repair service center, they will be able to diagnose and fix the issue.
Hi:
The most common problem is the oil pressure switch. First make sure your machine has the oil up to the level line. If oil level is ok, then order the oil pressure switch and change it. If neither of these two actions cure the problem then send it in to be inspected by an authorized service mechanic.
The engine has low oil level shutdown. It may be the reason for stopping.
Use the welder only at level condition. Check the oil level, before every start. If no result, find and check the oil sensor contact (if possible replace with good to check). Try with disconnected and shortened contact prior to buying a new one.
It probably has lost all residual magnetic field from the rotor.
You may need to "flash" the field to restore operation.
Search Google for instructions. Sometimes others have found that plugging in an electric drill that does NOT have a throtling trigger and spinning it while connected to the generator will get the generation started again. There are other methods as well.
The probable caures is due to the coolant pressure, do'nt turn this full on, if it's from the mains tap turn on and notice a trickel from the outlet, one half turn of the tap should be ok depending on the water presure. If its from a recirculation tank check the vale govener inside the tank. The torch data will indicate the coolant pressure
