At first the brake light was working but the tail light on that side was not functioning (bulb was good). Eventually, brake light didn't work. Radio will come on but no sound at all (static or nothing). Battery seems to be draining while sitting for a while.
SOURCE: 2001 Chevy Lumina brake lights not working
test and replace the brake light switch, it is located at the top of the arm the brake pedal is attached to.
SOURCE: rear brake lights don't work
you prob got a trailer plug prob bad wires if not tail lights run through turn signal switch tell fix ya bout me ok
SOURCE: I have A 2000 Chevy 3500 Express Van and the brake
When you said that you checked the brake switch, did you check it live? Meaning verified live power to the switch, press switch, and then power came out the other terminal?
If so, also verify zero power on brake press, at the offending brake light bulb terminal. You must verify the test light each time you move it...leave running lights on...
After verifying that there is no power coming, after the brake is pressed, note the wire color and find it where it comes to the steering column and test there... This would eliminate wires and connections between front and the rear of the vehicle, unlikely, but needs to be tested.
After verifying no power at that terminal, then yes the t/s switch is certainly suspece. This may be the time to get a mechanic to verify and replace the switch, there are locks, tilt mechanisms, air bags, column bearings, etc involved. Failures risk loss of vehicle control (locking or binding for example.)..
Hope this gets you going in the right direction.
Testimonial: "Thank You. I tried those things and it seemed to be the Emergency Flasher switch in the multi function switch."
SOURCE: 99 Chevy Tahoe... Rear turn signals, brake lights, and hazards
I had this problem, and to be honest, it happened to the left side about a week later...it's the board that the bulbs plug into...it's a very common problem with this model. So popular that you can normally get the socket board off the shelf at a parts store! it's extremely simple to replace, and I replaced all the bulbs at the same time!
