Measuring Tools & Sensors Logo
G
Gene Hallahan Posted on Nov 19, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I get outside temperature on my device?
I changed all the batteries and the information given by the weather station all function but the outside temperature. I need help in getting this function to operate.
Shimon David
Level 2:
New Friend:
  • Expert 52 Answers
  • Posted on Nov 19, 2015
Shimon David
Expert
Level 2:
New Friend:
Answers
52
Questions
Helped
13332
Points
145
What is your device ?
My figure has DigiTech XC-0366 wireless weather station is not collecting the outdoor temperature
Your 'figure'??
Normally it has to be done in order. Remove both lots of batteries. Put the base unit batteries in first and then put in the outside unit batteries. they should pair. In fact the manual states that.
Instructions:
- Open the battery compartment on the weather station and insert 2 x AA
batteries, taking care to put them in the correct polarity. Close the battery
compartment.
- Open the battery compartment on the transmitter and insert 2 x AA batteries,
compartment.
Note: Ensure to install the batteries into the weather station and transmitter
within the same hour to ensure that they synchronize properly.
DigiTech XC-0366 User Manual - ManualsLib
https://www.manualslib.com > ... > Weather Station
View and Download DigiTech XC-0366 user manual online. Wireless Weather Station With Outdoor Sensor. XC-0366 weather station pdf manual download.
I have the Atomic Clock model W86111. I had to change the batteries on the outside device. The clock outside temp just flashes 63.5 all the time. How do I make it sync to the device outside?
Remove all batteries from outdoor sensor and weather station.
Press one of the buttons on the weather station at least 20 times to clear all memory.
Verify that the weather station is blank before proceeding (there may be lines painted on
the screen that will show when power is removed).
Leave both units without power for 15 minutes (very important).
Insert fresh batteries into the clock.
Insert fresh batteries into the outdoor sensor.
Press the TX button on the outdoor sensor to transmit RF signal.
Keep the outdoor sensor 5-10 feet from the forecast station.
When RF connection is established, the temperature will appear on the station. Allow the
outdoor sensor and weather station to sit together for 15 minutes to establish a strong
connection.
Oct 14, 2017 • Home
Acurite weather forcaster not showing outside temp
Here's the manual for the AcuRite Weather Forecaster. If it's not showing the outside temperature, make sure the A-B-C switch is set to match the display unit. Not doing so might be the reason it's not synchronizing and displaying the outdoor temperature. https://www.acurite.com/media/manuals/75077-75107-instructions.pdf
My weather station is no longer recieving an outdoor temperature reading. The barometer is working fine, as is the indoor base station. Both were given new batteries at the same time, and the set up i
hi,
does the outside humidity working ?
if yes - the outside station is transmitting but the temperature sensor is faulty,
if no sensing is available from the outside station, it look like the outside station is faulty . (this is common because of extreme weather change.
notice that the pressure sense is done in the base station.
regards ,
Daniel
https://www.rylwy.com/
The sensor from my weather station is not registering outside temperature
I've had the same problem since I bought this unit 2+ years ago; when the outside temperature moves into the freezing zone, the sensor stops transmitting. I contacted Lacrosse-- all they could suggest was change the batteries. My solution: throw it in the trash!
C Tech Weather Station. How do i reset the outside temperature. Meter says it's off?
Is the outside unit LED on? I replaced the battery on the outside unit and in doing this reset the outside information.
Top Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
