Home Logo
B. Warden Posted on Nov 19, 2015
I just bought a jacuzzi toilet, it came with a slow close toilet seat. The seat does not seem to be the right size for the elongated bowel. Its seems to be short. Has anyone had this problem?
You can see 1/4" of the bowel around the seat. I'm wondering if they mixed up the seats when packaging.
5 Related Answers
Anonymous
  • 10865 Answers
  • Posted on Jan 31, 2009
SOURCE: elongated toilet doesn't fit where a round toilet was installed
Hi. There are toilets designed to accept a round seat and there are other toilets designed to accept an elongated seat. The primary difference is that the round seat fits a round bowl and the elongated seat fits an elongated bowl.
I recommend that you return the elongated seat and exchange it for a round toilet seat. good luck
john h
  • 29492 Answers
  • Posted on Jan 22, 2010
SOURCE: Jacuzzi Era elongated seat attachment
first need to buy the longer oval seat so it sits correctly at the front most mounting screws are universal-- go buy thin rubber washers and trim and place between the hinge and bowl than tighten down this will stop slippage but the front if not correctly sitting on the bowl will still cause problems
Anonymous
  • 128 Answers
  • Posted on Mar 21, 2010
SOURCE: Item: Kohler toilet seat. 4734-0, Rutledge Quiet
I would stack washers on the underside of the nut.
Anonymous
  • Posted on Aug 18, 2010
SOURCE: Need to order a replacement toilet seat for Model
I have problems with booths of my toilet seat.
When sitting down it move's & every think is tide .
My question is WHY ?????????????? It is also very unsafe, you feel like you will fall of the seat.
Anonymous
  • 70 Answers
  • Posted on Oct 30, 2010
SOURCE: My Kohler slow close elongated toilet seat is
this type can not be adjusted.
2answers
Is there a site to buy Whisper Close or Soft Close 'hinges only' for a Bemis Whisper Close elongated toilet seat.
https://www.choicereplacementtoiletseatshop.co.uk/c/spare-parts/toilet-seat-hinges
Jul 02, 2015 • Bemis Home
QUIET CLOSE TOILET SEAT COVER CLOSES VERY, VERY SLOWLY. HOW CAN I CORRECT THIS TO CLOSE FASTER>
There is no adjustment for a slow close/quiet close seat. It would defest the manufacturers intent.
2helpful
2answers
Need to order a replacement toilet seat for Model Jacuzzi Era toilet. We have looked at Lowe's and other home improvement stores and all the available elongated replacement toilet seats do not seem to be...
Try checking plumbing supply houses instead of home improvement stores. Im not sure where you are located. Here in MO. I use Harry Cooper Supply or Riback Supply or Southern Materials. A good supply house should be able to help you find what you are looking for. Hope this helps.
2answers
Have to replace two new toilets seats,the seats move
Martin, Jacuzzi has a one year warranty on toilet seats so if you have defective seats and they were purchased less than a year it is covered you will have to find a dealer near you, I provided a link for you to accomplish this. How is the seat attached? There should be two plastic screws with a nut on the underside which can be tightened these tend to loosen and nee re-tightening every so often. I hope this has helped. Thanks for using FIXYA, good luck and have a great day. Jeff
Find A Jacuzzi Dealer
11helpful
Slow closing toilet seat not working
It needs a new air shock on it. You might be able to take the old one apart and fix it but replacement would be best.
Elongated toilet doesn't fit where a round toilet was installed
Top Jacuzzi Home Experts
john h
Gene Lawson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
