Transfer roller is replaced Keeps on showing message Need to replace transfer roller soon .
1. Touch Menu.
2. Touch [Counter].
3. Touch [Display Keypad].
4. Press the following keys in this order.; Stop -> 0 -> 0 -> Stop -> 0 -> 1
5. Enter the CE password and touch [END]. (IF required)
6. Counter
7. Life
8. Transfer Roller Clear
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
The error message under that title is "Have the image transfer belt replaced soon." It's a new unit, but resists doing the Gradation Adjust. Tried returning the old belt (which was working before the replacement) and error message remains, so apparently the problem is not with the new belt.
System Error Clear (System 1 -> Initialization) gives "Result: OK" but has no effect; the problem remains after machine restart. However, it does NOT at any time give L-5 error (Transfer belt unit accumulated rotation time excess warning), just continues to say "replace image transfer belt unit", and will not allow anything else to proceed. What am I missing? (Transfer belt clutch malfunction?
Your printer monitors the life of your transfer belt. When the transfer belt reaches the end of its
life, the printer displays
80 Belt Exhausted. This message indicates it is time for you to
replace the transfer belt. For best print quality, make sure you replace the transfer belt when
80 Belt Life Warning.
Press
Go to clear the message. The Supplies message appears on the second line of the
display to remind you that supplies need attention. You can open the Supplies Menu to see
80 Belt Exhausted
or 80 Belt Life Warning messages.
The printer continues to display the
Supplies message until you replace the transfer belt. To
replace the transfer belt, use the following steps or the instruction sheet supplied with the
transfer belt.
