Sky remote code for lg 37lc46 - Televison & Video
  • 2 more comments
  • Anonymous Dec 31, 2007
    Anyone know the sky remote code for lg 37lc46 yet??
    Thanks in advance
  • Anonymous Feb 07, 2009
    we have a Daewoo 37 inch need code for sky remote version 8
  • anne357 Mar 08, 2009
    i have a 52 lg tv whats the sky remote code
  • rachelcowan7 Apr 07, 2009
    remote not operating
For sky plus remote ver 8 the code four number is 0206
the three number code is 206
Posted on Feb 03, 2008
Hi for the 57 TV Toshiba Regza z3030 series. for Sky Plus, I found the three digit code worked for sound etc, was 063. Get Sky Plus Remote Turn away from TV . Press TV on Remote, It will flash Red twice. put in code 063. and your away. sometime after code you have to press Select again,or TV ,but away from TV.
Posted on Oct 02, 2008
Only solution is to get a ver 8 remote, you prob have a 4 or most likely a 6, check under battery cover
Posted on Jan 06, 2008
Remote controls working but unable to operate the tv
Posted on Dec 23, 2007
3 Suggested Answers
SOURCE:
  • 27 Answers
SOURCE: Sky remote code
0206 usually works for LG
Let me know if any success
Posted on Apr 08, 2009
SOURCE: sky remote code for lg 42LD450 42
hi code is 0206 works fine with mine
Posted on Dec 28, 2010
I have a LG TV 37LC46-ZC with LG surround sound DVD Player/Amplifier LH-T550TB and a Sky HD Box. This used to work fine through the scart leads on the old sky box but since I changed over to HD Box I...
I know that's not all that helpful at the moment but I know that the no video out (to run a 2nd tv) that's there way of getting you to have a 2nd sky box I hope that is not the case with audio but it is a possibility ..try using phono plugs
audio out (RED WHITE omd audio in on your amp I have a look about and repost
Nov 26, 2017 | Televison & Video
What is the code for LG 37LE4500 TO WORK WITH SKY REMOTE CONTROL
I also have an LG TV. I used this 4 digit code: 0742.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Mar 12, 2011 | LG Televison & Video
What is the TV setup codes for LG TVs for the SKY remote?
Here are the codes for LG TVs for the sky remote.
Codes provided by SKY:
0037, 0056, 0060, 0065, 0080, 0081, 0125, 0137, 0178, 0191, 0204, 0244, 0245, 0275, 0318, 0389, 0391, 0398, 0405, 0459, 0502, 0742, 1146, 1367.
Codes provided by LG:
0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851
Regards,
sjstore2
Dec 18, 2010 | Televison & Video
Hi i need code for my tv lg 37lc46 hdlcd has i need to re install my remote
hi! i have here a couple of codes for your LG TV, just try them, 1343, 1346, 1396, 1005, 1396, 1397, 1398, 1399, 1402, 1403, 1404, 1405, 1501, hope this helps!!! goodluck!
Jun 09, 2010 | LG 37LC7D 37 in. LCD HDTV
Sky remote code for lg 42LD450 42
May 24, 2010 | LG 42LD450 42 in TV
SKY REMOTE NOT WORKING WITH MY NEW LG 42LH3000
To use sky+ remote control with LG 42LH3000 you must have a rev ver8 remote controller.
The codes are stored in a database of the Sky remote. If the old codes don't work
you may need to buy the latest Sky remote. Otherwise it is a matter of waiting for the
new Sky remote which may have the updated codes.
Note: LG Support supplied the following for Rev.8: 0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851.
Version 1: August 1998
Version 2: December 1999
Version 4: May 2001 (Sky+ introduced)
Version 6: March 2004
Version 8: January 2006 (includes all current Sky+HD remote controls)
Aug 11, 2009 | LG 42LG30 42 in. LCD HDTV
Sky remote code
Feb 07, 2009 | LG RZ-15LA66 15 in. LCD Television
Sky remote code for LG 42LC46 tv
After spending hours on this I found that code 0206 worked on my sky+ remote(with LG 42LC46). On an old sky remote, prior to version 4 (inside the battery compartment), just use 206.
This code was actually for a LG 42PX5D but it works perfectly on my tv.
Jan 14, 2008 | LG 42PX5D 42 in. Plasma HDTV
Sky remote code for 37LC46
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0056
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Dec 27, 2007 | iLO 3200 32 in. LCD Television
Sky+remote code for my lg tv
The cose you need is 0206
Sep 15, 2007 | Televison & Video
Televison & Video Logo
1,991 people viewed this question
Top Televison & Video Experts
Ekse
