Follow the detailed instructions below on how to completely reset your RCA Android 5.0 tablet.
Applicable models: RCT6773W22B, RCT6203W46KC, RCT6213W87DK and RCT6303W87DK
Step 1. With your tablet off, press and hold the volume up (+) button and power button until you see the RCA splash screen with Nipper and Chipper. Release both buttons to reveal the Android bot on his back with a caution symbol above him.
Step 2. A new screen will appear asking you to use your volume up/down keys to move and the power button to select.
Step 3. Use the volume down (-) button to highlight "wipe data/factory reset." Once highlighted, select using the power button.
Step 4. A new screen will appear asking you to confirm your selection. Use your volume down (-) button to highlight "Yes -- delete all user data." Press the power button to select once highlighted.
Step 5. Once the tablet is finished wiping data, you may press the power button to select "reboot system now." This will restart your tablet.
Step 6. The system will begin to reboot and once again display the RCA logo with Nipper and Chipper. The next "Welcome" screen will prompt you to select your language of choice. Scroll through the options using your finger and press start when finished. Congratulations, you have successfully reset your RCA 7 Voyager tablet.
How to completely reset your RCA Android 5 0 tablet
SOURCE: I forgot password on my RCA tablet. How can i reset it? I need a hard reset, how do I do that?
While it's turned off you hold the volume up and power buttons. Then when the android appears release the buttons. Hold the power button and press volume up. Navigate with the volume keys and select factory data reset. Hopefully this isn't the method you'd already tried.
SOURCE: How do I hard reset RCA 10" tablet??
You need to do a factory reset, follow these instructions:
Step 1. With your tablet turned off, press and hold the volume up (+) button. While holding the volume up (+) button, press the tablet's power button until you see the RCA logo with Nipper and Chipper on the screen. After a few seconds, the screen will change and you will see the Android bot on his back with a caution symbol above him.
Step 2. Now you are going to press and hold the tablet's power button, and without releasing the power button press down on the volume up (+) button. You should then see the screen below.
Step 3. Use the tablet's volume up (+) and down (+) keys to navigate to and select the "wipe data/factory reset" option. To select this option, press the power button.
Step 4. The tablet is going to ask you to confirm your selection. Use the tablet's volume up (+) and down (-) keys to navigate to and select "Yes - delete all user data." Once again, use the power button to select this option.
Step 5. At the bottom of the next screen, you will see "Data wipe complete." Press the power button to restart the system.
SOURCE: How do you hard reset a RCA Tablet model number RCT6293w23 ??? I cannot access any of the settings
Here's a video.. look for the red for what/where toy press.
http://www.rcatablets.com/how-completely-reset-your-rca-android-pro10-tablet-android-44
SOURCE: trio stealth lite 4.3 tablet. Forgot passcode. How do I factory hard reset?
Chech websites:
Trio Stealth Lite 4 3 Internet Tablet Reset
http://www.androidtablets.net/threads/trio-stealth-lite-4-3-internet-tablet-reset.60227
