AT&T GoPhone ZTE Maven 4G with 2GB Memory No-Contract Cell Phone Logo
How do i transfer my Music from phone memory to SD Card
Iam having issues transfering my sd backup to my phone it says internal memory full?
You will have to delete some stuff off of your phones memory. Games, pics, music ect. I recommend deleting items that you either don't or rarely use. If you would rather not loose any of them get another SD card and transfer all of the things to it so it frees up memory on your phone.
Nov 24, 2015 • Cell Phones
1helpful
Can't transfer my music to LG800g micro SD card. It will go to internal memory only.
you have to download a file moving app or viewing app. it should allow you to copy the music files on your phone and past them to the sd card. This may work but if not you may have to reformat your sdcard and but that will wipe everything on your card. Another solution is to get your phone rooted is what you may have to do giving you acess to move files around better
2answers
How do i remove the write protection on my galaxy s sd card
need to remove the write protection from the PHONE MEMORY so i cant delete anything . remove-write-protection-galaxy-s-sd-card-0mcgnre0akckbqsgiub3i30g-3-0.png
kindiy anybody help on this
4helpful
How do I transfer.music.and.photos. from phone to PC? Thank you., Betsy
If you have difficulties connecting your cell phone to your computer and unable to download the photos and music files to your computer. If these files are stored on the SD card on your cell phone, then remove the SD card from your cell phone and insert this SD memory card into an USB memory card reader.
Connect the USB memory card reader into the USB port in your computer. The computer will see the SD memory card as an external storage device, you can then open the various folders on the SD memory card and copy the files to your computer.
I cannot transfer music from micro sd to my kyocera phone
You should not need to transfer the music from the sd card to the phones memory, but play the songs directly from the sd card. Once the songs are loaded onto the sc card in the right format, (MP3) your phone should find them on the card.
3helpful
How can you import pictures in inbox on cell phone to the microchip SD 2gb inserted in phone?
Micro SD cards for cell phones are now costing less and are holding more memory. 4GB SD cards can hold an estimated 1000 songs, over 13,000 images, or 22 hours of video individually. 2GB memory cards hold roughly half those estimates and 8GB SD cards would hold double. So if your cell phonemag-glass_10x10.gif has a SD card slot learn how to utilize this expandable memory option on your device. Follow these steps and you will soon be enjoying your music, pictures, and video on your phone!
  1. Insert your SD memory card adaptor (with micro SD card inserted) into your SD Card drive on your computer. This should open a "Secure Digital Storage Device" or similar window. If not, go to "My Computer" to locate your SD card and open it.
  2. Step 2 To transfer picture files to your SD memory card, open the folder or file that your pictures are stored on. Simply click and drag a file or multiple files and drop them into your SD Card window or folder. You can also copy a picture and then paste it to the SD Card.
  3. Step 3 To transfer music files to your SD memory card, open your "My Music" folder. Select the folder where you are going to get the music from (Itunes, Yahoo Music...). Click, drag, and drop the files into the SD Card window or copy and paste them in.
  4. Step 4 To transfer video files to your SD memory card, open your "My Videos" folder. Select the folder where you are going to get the video from. Click, drag, and drop the files into the SD Card window or copy and paste them in.
  5. Step 5 Take out the SD memory card adaptor from its drive. Remove the Micro SD card (small chip for your phone) and insert it into the SD Card drive on your Blackberry, IPhone, or other compatible cell phone.
  6. Step 6 Go to your media, picture, or music folder in your cell phonesmag-glass_10x10.gif menu. Select which item you are looking for and your files will appear!
Nov 14, 2009 • Cell Phones
1helpful
When trying to transfer music, it says my memory is full its not
Check for Is there any slot for Card Like Micro SD card. In this slot you can insert your micro SD memory card ... Well before doing this you have to buy memory card if it is not given by your mobile..
Regards
3helpful
2answers
How do i upload music from my micro sd to my phone
Does your phone support external memory? If so, just plug the micro sd to your phone.
7helpful
5answers
J700 insufficient memory with memory card
siply change settinngs in phone go to :
PHONE SETTINGS->PC CONNECTIONS->MASS STORAGE
and that is it
Need help
you need to install memory card in phone then attach a data cable specfically for your phone (available at cell phone dealer) into phone and the other end to the usb of the pc if our phone came with software load it on pc then use the software to transfer the music files from your pc to your phone.
Top AT&T GoPhone Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you an AT&T GoPhone Cell Phone Expert? Answer questions, earn points and help others
