2001 triton 2700 twin 250 optimax ,,lost 10 m.p.h. when I took 225's off
SOURCE: i have a 97 2.4l twin cam in 2001 will it work
It will work as long as you have the ECM to match the Motors. The regular 2.2 has a different engine management system then the 2.4 so the engine will fit but the ECM needs to understand the engine.
Good luck and hope this helps.
SOURCE: need to replace the altenator on a 2001 saturn sl1
1)Remove serpentine belt from above with 14 mm wrench on spring
loaded idler pulley.
2)Disconnected battery
3)jack up car and remove passenger front wheel
4)it helps to also remove the wheel well splash panel also for better
access.
5)crawl under car and remove battery and other connectors from the
alternator. then remove lower attachment bolts (I think there are 2
below to deal with-one is for a support bar, and one is an alternator
attachment bolt)
6)go back up to top of car and remove upper attachment bolt (this one
is a little hard to get to)
7)pull alternator out and have a alternator shop repair bad rectifier
board and any other items that need attention.
8)reinstall repaired alternator
9)leave splash cover off to provide additional cooling to the
alternator area. put wheel back on and lower car.
10) install new serpentine belt from above and reconnect battery.
If you have the time you could get the newer improved alternator from
6th planet. It has shields to improve the heat disipation.
Thank you Sir, Have a nice day.
SOURCE: My 1999 Alero makes a noise like a Twin Prop
CHECK FOR LEAKING OR LOOSE SPARK PLUG OR LOOK FOR A EXHAUST LEAK AROUND CATALYTIC CONVERTER TO MUFFLER.
SOURCE: what are the timing marks
http://www.2carpros.com/questions/chevrolet-cavalier-2001-chevy-cavalier-timing-chain
