Every time it opens it closes back down again. Do you know how I can fix this? I have already installed and reinstalled it.
SOURCE: won't open or close tries to run but stops
The fault code (4 blinks) is informing you of an issue with the infrared sensor that detects an obstruction in the path of the door.
It is ether misaligned or an issue with the wires leading to it or its faulty.
If the red beam is present at the sending unit (affixed to the doors frame), then it should be aimed at the receiving unit (affixed to the opposite frame) If the beam is received then there should be a green indicator light illuminated.
Good luck
Aduz
SOURCE: my e66 cannot send text messages....it shows the
sir your phone memory is full.empty your inbox and outbox and format your handset by using the following code *#7370#
it will require your phone lock code which is 12345 in default.
good luck
