DeWALT DW433 Type 1 3 21 Variable Speed Belt Sander Parts
And the correct tools
SOURCE: Motor runs but the drive drum that hold the sanding belt does not turn.
Instead of removing the drum, remove the belt and the cover over the gearbox. The gearbox cover is normaly fixed in place by screws around the drive pulley. There may be a couple of screws under the pulley, if so they can be accessed via holes in the pulley wheel itself. Check for worn or stripped gears. These gears can be replaced if need be, but if this is the case make sure you remove and clean out all the grease first and replace that aswell as it may contain bits of teeth that have come off the faulty gear. As far as I know belt sander drive rollers can not be removed without removing the drive inside the gearbox first.
SOURCE: I have a Canadian tire model 55-3550-2 belt/disc
I went to a bearing/powertransmission supplier. The number on the belt was all they needed. Picked up a new belt for $6.50.
SOURCE: Dewalt DW433 belt sander stop working, why?
Check the brushes for the motor they may have gone bad or broken, I have seen this happen before on dewalt tools.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
SOURCE: broken drive belt on belt sander
My answer comes almost a year after the original question, but I'll post it anyway for those who end up here after a search.
Black & Decker no longer supplies drive belts for the BR400 sander, but you can get a replacement elsewhere if you know what to ask for.
The belt is a synchronous, single-sided "XL" series belt, and mine had 120XL031 printed on it. The belt width is 0.31in or 5/16in or 7.9mm. Its pitch (distance from tooth to tooth) is 0.20in or 1/5in or 5mm. Its total height is 0.09in, and tooth height is 0.045in. It has 60 teeth, making the total length 12in.
I found a replacement at sdp-si.com, part number A 6R 3-060031.
Look here for timing belts (inch), then narrow the search for single-sided, .200 (XL) pitch, 60 grooves, 5/16 width.
SOURCE: dewalt d26451 type 1 random orbital sander. why
I have the same problem with a Porter Cable orbital sander I recently purchased. Whats happening is the sander is catching the edge of the board you're trying to sand and jerking back and forth as the sander base spins. It seems that if the board your're sanding is at least as wide as the sander base, the problem goes away, which does little good because there will be many times I we'll need to sand wood that is less in size. But you may try using a lesser grit sandpaper and see if that alleviates the problem somewhat.
